1985 L series brumby leaking
Looking at purchasing the above car and have been told its leaking oil alot when its running. So much so I wouldnt make the hour long drive back home.
is this a common problem? It sounds like while the cars running, its leaking like a sieve from somewhere where it has too much pressure.
Any thoughts?
Any thoughts?
L Series and Brumby are different things. L's are shape after the commonly known Gen2 Brumby.
Oil pressure switches can blow and leak real bad. new one for about ten bucks - is one suggestion. Located RHS at the front just on the oil pump, RHS of main crank pulley
About same location for either std Brumby EA81 or L Series EA82 OPS
- thunder039
