L Series Suspension Squeak
Kelossus
Post by Kelossus » Tue May 29, 2012 9:14 pm
Hey Guys
I have an annoying squeak coming from the rear of my car. It sounds like its coming from the rear springs/struts.
Every time i push down on the car it squeaks. Even getting in out of the car causes it to squeak. Is this a major issue?
I have some picture of my springs and struts, i know this isn't going to help but is this the stock suspension? I can see a KYB sticker on the front struts so i know that is aftermarket but are the springs on the front and rear stock?
http://www.freeimagehosting.net/rfqmi FRONT
http://www.freeimagehosting.net/n33mc REAR In this rear pic you can kinda see the insert bit is out of tube. Is this normal?
Also is suspension very hard to change yourself?
I am not very mechanically minded but I'm not useless. Do I have to take the wheels and everything off to change the struts and springs?
Brumby Kid
Post by Brumby Kid » Tue May 29, 2012 10:27 pm
Ok.
To change I would say yes you can.
Wheel off yes. And jack the car up high so the spring is fully extended.
Hub off I doubt it. Should just unbolt from the hub ( or whatever it's attached to).
I would Probebly get a suspension/ wheel shop to check/ get it aligned properly.
This info is just from what I have picked up from other members, and common sense. I don't really know what to do.
Others will clarify.
Cheers Cam
Dads Car: 02 Impreza WRX STi
Post by steptoe » Tue May 29, 2012 11:47 pm
shove a garden hose under each corner at a time, turn tap on, wet everything, take for test drive or bounce - any noise go ??
You are learning, stay in here, keep asking questions, check and double check your work.
Can you record the sound to shove in here ??
Post by El_Freddo » Wed May 30, 2012 12:37 am
It's probably either the rear struts' lower bush or the rear bushes squeaking.
My rear right needs a new lower bush on the strut as it's squeaking every time you get in/out of the car or as soon as you hit the slightest bump in the road.
