Maximum revs for std EA81
Hi Guys, Can anyone tell me what should be the maximum rpm of a std EA81 Motor?
Regards Buddyboy
Regards Buddyboy
Regards Buddyboy.
"Subaru, when only the best will do".
- Brumby Kid
Not sure sorry. Why do you want to know?
There is one easy and very fun way to find out....
Anyone got a spare EA81 they would like to donate?
- TOONGA
mmmmmm flat top pistons ... mmmmmm, only problem with over revving and EA81 is bending valves. Oh apparently you can safely rev one to 4800 rpm or unsafely to around 6500
EA-81
The Subaru EA-81 engine was produced from 1980 to 1989 and is a stroked version of the EA-71.
Specifications
Displacement: 1,781 cc
Bore: 92 mm
Stroke: 67 mm
Compression Ratio: 8.7:1
Valvetrain: OHV Pushrod
Horsepower: 73 bhp (54 kW; 74 PS) at 4,800 rpm
Torque: 94 lb·ft (127 N·m) at 2,400 rpm
EA-81
Specifications
Bore: 92 mm
Stroke: 67 mm
- Silverbullet
- Brumby Kid
Same. Not that mine is an s. just highly modded.
Oh spoilers... Will post pics tomorrow. Got it back Friday night.
Just need to wait till I can put it in.
Cheers Cam
Cheers Cam
TOONGA wrote:If the valves in an EA81 hit the pistons, a conrod has given way or a valve and/or a collet has broken
[SIGPIC][/SIGPIC]88 Subaru Brumby (Currently being restored.
84 brumby 2 inch Lift(very rough, Big tires)
Landrover series two. 186 holden banger under hood.
If in total standard form (i.e. tyres, rims, driveline, etc) the MY have revlimit marks on your dash which show the maximum speed at which gear can be held at. I don't have a tacho gauge on mine but working through the rolling diameters, ratios and simple maths you should get something pretty close.
- Silverbullet
This is true, I never noticed them until dad pointed it outRSR 555 wrote:If in total standard form (i.e. tyres, rims, driveline, etc) the MY have revlimit marks on your dash which show the maximum speed at which gear can be held at. I don't have a tacho gauge on mine but working through the rolling diameters, ratios and simple maths you should get something pretty close.
I have had mine up to 8 grand, was screaming, and i think may have had more, but i wasn't game...
"Claudia"
"Claudia"
- Brumby Kid
Was that the turbo or dual port heads engine?
Btw what does dual port heads mean?
There are no 'true' dual port EA81's, some EA81's had the intake and exhaust valves in opposite positions and the divider in the exhaust port came all the way to the surface.
The EA62 was the only engine to have dual exhaust ports
The Dual port, EA81T runs out of power long before 8 lol
"Claudia"
"Claudia"
Also search on Google there is some good pics on there showing the differences in the heads.
"Claudia"
"Claudia"
Ahhh... No (Don't Believe Wikipedia)!Gannon wrote:The EA62 was the only engine to have dual exhaust ports
The Subaru flat four engines all had dual exhaust ports up until the revised EA63 in 1975/76... That means EA52 through to EA63 had an exhaust port on the front and rear of each head. Once the revised EA63 was released most EA engines had siamesed exhaust ports that exited from the bottom of each head.
Incidentally they also went from extremely quiet engines to extremely loud, like a certain chaff cutter four...
Old Boxer Tricks
1980 Brumby
1978 4WD Station Wagon
1974 DL Sedan
1974 GSR Coupe
1980 Brumby
1974 DL Sedan
1974 GSR Coupe
- Brumby Kid
Cool, didn't think these existed, surprised the twin carb doesn't have them.
Dual intake as well?
Where can I get some?
Will have to see how my ported heads do compared to the dual ports.
Cheers Cam
Cheers Cam
- Silverbullet
Don't think the 63 heads would be compatible with 81 engine, there's also the fantabulous contraption of an exhaust manifold you'd need to make; 4 pipes coming from each corner in opposite directions
- Brumby Kid
I mean the heads that Matt has. Those twin port.
