AWD 12kg Centre Diff LSD Group Buy
Post by NachaLuva » Tue May 22, 2012 2:07 pm
I have been thinking of upgrading my centre diff for a while. Having seen the difficulties & expense of modifying the gearbox with a locking centre, I was thinking a 12kg centre LSD to replace the standard 4kg might be better.
So...I was thinking a group buy might be an idea... Image
If you're interested or have any info on where is the best place to get them, post here...
There is a parallel thread on OffroadSubarus:
http://www.offroadsubarus.com/showthread.php?t=3673
Davidov
Post by Davidov » Tue May 22, 2012 2:13 pm
I would probably be keen depending on price, in WA but.
d_generate
Post by d_generate » Tue May 22, 2012 6:34 pm
Much better buying individually direct from Japan, because it's less than $1,000 no tax or GST,
http://www.japanparts.com/db/partslist. ... EY=&page=2
how about this one for around 700
http://www.japanparts.com/db/parts_deta ... RCH_page=2
Davidov
Post by Davidov » Tue May 22, 2012 7:02 pm
So why are none of them suitable with ABS?
d_generate
Post by d_generate » Tue May 22, 2012 7:24 pm
No idea, DCCD seems to be ok but I'd still disable it off road, way too dangerous.
taza
Post by taza » Tue May 22, 2012 8:10 pm
d_generate wrote:No idea, DCCD seems to be ok but I'd still disable it off road, way too dangerous.
You mean ABS?
I always pull my fuse as it gives me the shits and is dangerous.
fredsub
Post by fredsub » Tue May 22, 2012 9:07 pm
sure is, i've known about it, but wasn't too concerned myself about it until few weeks ago going around a bend and finding another vehicle in my path opposite and hitting the brakes did nothing,
so quickly swerved around.
have to come up with a more convenient way of disabling ABS for the off-road than pulling the fuse though....
purp
Post by purp » Tue May 22, 2012 9:25 pm
fredsub wrote:sure is, i've known about it, but wasn't too concerned myself about it until few weeks ago going around a bend and finding another vehicle in my path opposite and hitting the brakes did nothing,
Should be pretty simple to wire a switch in series to the fuse... Not sure about the legality of that...
Post by El_Freddo » Thu May 24, 2012 3:31 pm
Davidov wrote:So why are none of them suitable with ABS?
Because the manufacturer is probably covering their arse.
d_generate
Post by d_generate » Thu May 24, 2012 5:31 pm
taza wrote:You mean ABS?
Ahh, old age slipping in there...........Yes ABS.:rolleyes :-?
