EA 81.. Can i run on unleaded?
- scoobymine
I've been reading some old forum posts about this. I've been adding valve saver to my 83 Brumby for ever, but some suggest you can use ULP or PULP. Can anyone confirm this. Thanks!
- thunder039
- scoobymine
- thunder039
did the ea81 require leaded? i didnt think they didVenom wrote:Cars made to run on leaded petrol require the lead to lubricate the valves. Without it they burn out prematurely, hence valve saver stuff. Nothing to do with octane per se, although leaded petrol was 95 octane.
Sent from my GT-I9100T using Tapatalk 2
2004 subaru forester -gone
1999 subaru forester- no more
1989 subaru brumby- sold!
2008 zook jimny -sold!
- Brumby Kid
On my fuel tank it says 95 oct. suggesting 95 octane was standard / reccomended.
- Silverbullet
My 81' has blue (blue-green?) valve covers, I've never seen black ones but then I haven't seen many EA81's. Anyway I run it on regular 91, no problems to speak of except my seeping valve stem oil seals
- scoobymine
- scoobymine
- thunder039
someone who is older will be able to correct me on this, but i believe anything pre 1986 requires leaded petrol while after 1986 they can run on normal unleaded fuel. i believe leaded fuel was fased out in 1986. so with your car being a 1981 i would keep using your valve saver. mine being 89 i am able to run normal unleaded
And catalytic converters...TOONGA wrote:1985 saw the introduction of unleaded cars and petrol to Australia.
As someone's said already - alloy heads have hardened valve seats as the alloy doesn't stand up to the test of time as the metal is too soft.
If you want piece of mind, run with the additive, if you're not worried about it I personally wouldn't have an issue with not using the additive if I had an old EA81.
ea 81
I ran a 1982 ea 81 for years on unleaded and premium unleaded. i ran a cold thermostat and set the timing up different. On premium i got 650 km out of 55 litres and on standard i got 500 km. I didnt run additives at all. The motor never missed a beat.
Use The Fork Luke
You have alloy heads right ?? You should be right, but so we get a disclaimer going on your old engine that may crap out due to a number of things keep using valve saver and look after our rep in here !steptoe wrote:You'll read somewhere comment from an engineer society or the like, that all alloy heads use the hardened stellite valve seats that ULP and LPG requires for good valve life - so any engine with alloy head should be suitable to run ULP without any additive
- Brumby Kid
What's the difference between an old EA81 and a newer EA81?
Blue vs black covers?
- thunder039
