L Series. EA81 can I get a lower low range?
pinwa
Post by pinwa » Mon Apr 16, 2012 8:17 pm
Got a 92 L Series wagon. EA82. Going 14 inch wheels and bigger tyres and was wanting to know if you can get lower low range gears? Owned the same car years ago and remember the low range not being low enough once I put the bigger wheels on.
Post by El_Freddo » Mon Apr 16, 2012 8:29 pm
Pretty much the only way to do it is to change the diff ratio. And the easiest way to do this is to get an EJ AWD gearbox, a 4.11 ring and pinion gearset (front diff), L series 1.59:1 low range and put it all together in EA gearbox cases.
This will give you a bolt up AWD gearbox (to the engine) that's got the stock L series low range and will compensate for larger tyres with the 4.11 ratio diffs. This is a great setup for 27 inch tyres. You will need a custom tail shaft, custom (shortened) gear linkages and a gearbox crossmember...
I can't wait to have it!
pinwa
Post by pinwa » Mon Apr 16, 2012 8:38 pm
Thanks. That's exactly what I wanted to hear. But the only thing I don't understand is why the need of the AWD gearbox?
Post by guyph_01 » Mon Apr 16, 2012 8:43 pm
El_Freddo wrote:Pretty much the only way to do it is to change the diff ratio. And the easiest way to do this is to get an EJ AWD gearbox, a 4.11 ring and pinion gearset (front diff), L series 1.59:1 low range and put it all together in EA gearbox cases.
+1 Mwahahahahha, can't wait either:) ohhh ohhh don't forget the dccd or mec diff lock:p
Post by guyph_01 » Mon Apr 16, 2012 8:47 pm
pinwa wrote:Thanks. That's exactly what I wanted to hear. But the only thing I don't understand is why the need of the AWD gearbox?
You dont NEED it but its the better box you can aim for. It eliminates the front wheel spin the 2wd box give when you upgrade to the bigger engines. But if you stay with your old ea82 and with the bigger tyres you might be ok with the Fwd. BUT once you got the big tyres, the lower range gearbox. U'll next be wanting a bigger engine:) Like all of us:p
Post by El_Freddo » Mon Apr 16, 2012 8:48 pm
Because the pinion shafts are easily interchangeable and off the shelf. If you did the PT4wd gearbox you'd need to press all the lower gears off, then cut and shut the pinion shaft followed by re-pressing all the gears back on.
Plus the advantage of the AWD would be great to have too.
guyph_01 wrote:+1 Mwahahahahha, can't wait either:) ohhh ohhh don't forget the dccd or mec diff lock:p
Only if you can afford to do it. Adding the DCCD could be easiest as the L series AWD with the centre diff lock is much harder to find - plus you'll still need to do a cut and shut on the pinion shaft for the centre diff lock box.
Post by El_Freddo » Mon Apr 16, 2012 8:52 pm
guyph_01 wrote:You dont NEED it but its the better box you can aim for.
And it's easier to modify, see above.
guyph_01 wrote:BUT once you got the big tyres, the lower range gearbox. U'll next be wanting a bigger engine:) Like all of us:p
Not if you're changing the diff ratio in accordance with the tyre size you'll be running! That's part of the whole idea behind it. Changing to the 4.11 and 27's should bring the drive train back to almost a stock level of performance.
I've spoken to a fella about the diff ratio change to 4.11 and he said it'll transform my L series with the 27's. Add the EJ22 to this and it'll be an awesome combination!
Post by El_Freddo » Mon Apr 16, 2012 8:53 pm
Oh, and welcome to the forum! A great way to start!!
What part of Gippsland? I was in Lakes entrance for about 6 months last year over "summer"
