Subaru Brumby Dash Lights
dandrov
Post by dandrov » Thu Apr 12, 2012 10:47 pm
just a random question, is there anywhere you can get aftermarket dash lights for a subaru brumby.
cheers
Dave :)
Post by steptoe » Fri Apr 13, 2012 8:01 am
what, do you need to replace existing dash light bulb that not work or you want to modify for a different,more personalised look ?
dandrov
Post by dandrov » Fri Apr 13, 2012 10:14 am
The factory orange lights seem quite dim, i would prefer going for something a bit different (blue or something) if possible. If getting new factory bulbs were bright then i would look at it too but i think leds would come up a lot brighter
Post by steptoe » Fri Apr 13, 2012 8:24 pm
turn them up by turning the dimming knob at the tip of the light switch first ?b
SideShow
Post by SideShow » Fri Jun 15, 2012 11:15 am
i have been into a local electronics shop (jaycar) and asked the same question. they can provide new led's which they claim will fit and the appropriate diodes for bugger all cost. i think the led's were under a dollar each for the basic ones.
might be worth checking it out.
littlewhiteute
Post by littlewhiteute » Fri Jun 15, 2012 9:28 pm
LEDs don't throw light in all directions like incandescent bulbs do.
The orange will be the silkscreening of the gauge faces.
Fit new bulbs, clean and retension the bulb sockets.
Gary ;)
brockharro
Post by brockharro » Fri Jun 15, 2012 10:41 pm
let us know u go with the leds im thinking of doing the same
Post by Silverbullet » Fri Jun 15, 2012 11:32 pm
There's 2 types of LED, one focuses on a point and the others are frosted I think (can't remember what they're called I'm too tired :o) but the frosted ones do throw light in all directions.
Post by steptoe » Sat Jun 16, 2012 8:39 am
Will the LEDs dim with the dimmer ? Or will you have a bright light show at night, the darker the outside world - the more internal reflection you get from the inside of your glass and unless you have a safari style flip down windscreen like Daktari or the roo shooters in their 'Cruiser utes ......
revmax
Post by revmax » Sat Jun 16, 2012 8:43 am
Post by TOONGA » Sat Jun 16, 2012 9:47 am
Having had a brumby instrument apart completely to install a tacho where the clock lived, I can tell you the orange colour on the speedo dial is generated by an orange piece of plastic, that's shaped like a lightbulb surround.
It sits at the base of the speedo mechanisim and orange light is transfered to the cluster via a simple type of optical plastic. If you can get the same shaped piece of plastic from another subaru cluster of a later design it should fit (they are available in a green blue colour).
Good luck and buy a spare instrument cluster those buggers are fragile :)
