L series Rear Drums onto a Brumby.
revmax
Post by revmax » Sun Mar 04, 2012 12:00 pm
Why ? Cause they have an auto adjusment where the Brumby has a manual adjustment.
They should fit cause L series Rear discs will bolt up to the rear end of a Brumby.
Has anyone done it before.
Could make for a cheap upgrade for a Brumby
revmax
Post by revmax » Tue Mar 06, 2012 5:23 am
guess not !
Post by steptoe » Tue Mar 06, 2012 8:03 am
Why not, so long as you include the backing plate. SEARCH because I have read someone say can't be done but don't think they used the L backing plate
Post by guyph_01 » Tue Mar 06, 2012 11:56 am
why dont you just get the rear disks from vortex87 ,, they are quite cheap.
Post by steptoe » Tue Mar 06, 2012 2:41 pm
says sold pending payment
revmax
Post by revmax » Tue Mar 06, 2012 3:40 pm
yer I did.
But I have just wrecked an L and have the rear drum brakes on hand. I will try them if the opurtunity presents itself on another Brumby.
Just wondeing if anyone elsae has tried it.
Post by El_Freddo » Sun Mar 11, 2012 11:52 am
revmax wrote:Just wondeing if anyone elsae has tried it.
Done it. Works well and is as simple as the rear disc conversions except for all of those little springs etc.
Post by RSR 555 » Sun Mar 11, 2012 3:18 pm
revmax wrote:Could make for a cheap upgrade for a Brumby
Don't understand what you mean by an upgrade? as they are both the same size drum. The fact of the self adjusting just means 1 less thing to do at a service. Upgrade would be fitting larger drums, converting to disc or the best upgrade would be the crossbred kit.
IMO you'd only fit L drums if you had them lying around and you MY ones were toast.
Post by RSR 555 » Sun Mar 11, 2012 3:25 pm
Oh and yes to your question.. they swap straight over
revmax
Post by revmax » Sun Mar 11, 2012 7:45 pm
RSR 555 wrote:. The fact of the self adjusting just means 1 less thing to do at a service.
So 1 less thing to do would be an upgrade (see first line of first post) and I now have L drums lying around.
Thanks Bennie. That is all I needed to know.
Post by steptoe » Sun Mar 11, 2012 10:49 pm
I too would consider one, sorry, two less things to do at service time -as an upgrade as surely a car salesman would also :D
BUT, consider if you need to get drums off and the auto adjusters have got the shoes too snug on the drums to remove with ease, can they be backed off like the MY ones can be ??
Post by El_Freddo » Mon Mar 12, 2012 12:10 am
RSR 555 wrote: they are both the same size drum.
I think the L series is *slightly* bigger, but only by half a bee's . . . .
You need the L series drum for this conversion to work. At least this is how it turned out for me, not that it was a problem.
Post by RSR 555 » Mon Mar 12, 2012 2:27 am
revmax wrote:So 1 less thing to do would be an upgrade (see first line of first post) and I now have L drums lying around.
I read your first post and understood what you were saying, I just believe that one more complicated automatic system in your brakes doesn't make it an upgrade but each to their own. I prefer things without all the automatic bullcrap (hence the Brumby being such a good winner) but it's just me. Sorry :(
El_Freddo wrote:I think the L series is *slightly* bigger, but only by half a bee's . . . .
They have the same inside diameter and use the same shoes, so only time there will be a bee's willy in it, is when someone has skimmed them ;)
