Info re Hi Flow Head Camshaft
Buddyboy
Post by Buddyboy » Sat Feb 18, 2012 6:40 pm
I'm after any information on the camshaft that is suitable for use with Hi Flow Heads for an EA81 Engine, these are the heads that have the exhaust and inlet valves reversed. Can anyone help or is there a thread already?
Buddyboy
Regards Buddyboy.
"Subaru, when only the best will do".
coxy
Post by coxy » Sat Feb 18, 2012 7:58 pm
What you need is the genuine twin carb EA71~81 camshaft or try someone like Ivan Tighe or waggot engineering at Alstoneville north of Newcastle for a custom billet camshaft only options available unfortunately.
I have a complete engine as do some others and they generally are not for sale that often so when they do come up you jump them quickly.
spike
Post by spike » Sat Feb 18, 2012 9:58 pm
are you running this with the twin carbs?
if not i suggest you talk to phantom D
hes trying to build a geniune and from last thoughts he didnt have real deal heads
if not go genuine cams
Buddyboy
Post by Buddyboy » Sat Feb 18, 2012 10:31 pm
Thanks Coxy & Spike,
I started out wanting to us a twin carby setup, but now I am considering using a weber, less problems with balancing/tuning the carbys. I have spoken to phantom_D earlier when I was looking for the twin carby manifold and he gave me a few clues how to find them. So far I have been able to locate a couple of twin carby manifolds, both without original carbys, and two sets of hi flow heads. Can't seem to crack the twin carby cam. The guys I have been speaking to won't part with them for love nor money. Just found out yesterday that there is a guy here on the Gold Coast that can grind cams from a billet, and use to work for some big cam joint in Sydney, might have to find him and find out wots wot. Thanks for the comments so far, all info is gratefully accepted.
Regards Buddyboy.
Regards Buddyboy.
Matt
Post by Matt » Sat Feb 18, 2012 11:47 pm
I have hi flow heads and a 272 cam in bianca but i brought it like it is, but they are so worth it. Also running a Weber and she just screams :)
"Claudia"
Post by steptoe » Sun Feb 19, 2012 7:32 am
That'd be Mr Ian? Watson of Watson Race Cams
http://watsonracingcams.com.au/
from Peakhurst , Sydney !
Done all my cams last 30 years.
He told me 16/56 was about the steepest I should take my EA81 cam and I didn't listen second EA81 around, went for 20/60. I reckon 16/56 is the best grind for good al rounder on normal camshaft.
Hope he can help you
littlewhiteute
Post by littlewhiteute » Sun Feb 19, 2012 7:49 pm
spike wrote:are you running this with the twin carbs?
I'm building his engine for him, and they are dual port heads,;).
Gary ;)
Post by Silverbullet » Sun Feb 19, 2012 8:06 pm
Seems like EA81S engine/manifold/heads are more common than I thought; I've counted mention of five in this thread so far, and I know there's more out there.
So does anyone actually know the original cam that came in the engine? littlewhiteute does the engine you're building for Phantom have the original dual port heads-cam in it?
littlewhiteute
Post by littlewhiteute » Mon Feb 20, 2012 6:43 pm
The engine is an original dual port, has not been apart.
Not as healthy as most engines I've done, but shows promise.
Gary ;)
