WRX radiator into Serie 1 liberty
Does anyone know if a wrx radiator will bolt into a liberty? I am having problems with my car overheating while towing & highway driving with the air on. I have thought about fitting an oil cooler & will probably do that as well, but I imagine that a wrx radiator would work better than a liberty one & if it fits It would be a relatively cheap fix. Cheers, Rob.
i think they mount differently at the bottom (could be wrong) nothing a drill couldn't fix i dont think and you'll have a few outlets to block... but i'd say just look into an aftermarket radiator possibly dual core?
to do list:
to do list:
- d_generate
Forget it, they don't have a radiator cap, I tried everything to fit one in a n/a Impreza but gave up in the end, just couldn't get water into it through the available hoses. Also the mount is about 25mm lower on the WRX and it's not a little job, lots of unpicking & welding involved.
I'd say your radiator might be clogged or you've got a thermostat or head problem, mine has been running a >280HP STI motor for 6yrs on a standard Lib radiator and never been past half way whether in the sand or on the track.
