L series struts into an 89 liberty? advice please!
hypoman
Post by hypoman » Thu Feb 09, 2012 10:35 pm
hey does anyone know if the rear struts out of an L series would fit an 89 liberty wagon?
Ive got plenty of Lseries spares but no libertys.
any help greatly appreciated!
Post by El_Freddo » Thu Feb 09, 2012 10:58 pm
Not possible.
The L series struts are bascially a shock absorber with a spring mounted to it.
The Liberty's is basically the same, but the bottom of the strut bolts to the hub and is responsible for keeping the wheel vertical if you get what I mean.
stenno
Post by stenno » Fri Feb 10, 2012 6:22 am
I have a set you can have from a gen 1 series 2 wagon you can have for postage. Just swap the rear springs and top hats and they will swap over
hypoman
Post by hypoman » Fri Feb 10, 2012 8:42 am
thanks for the info stenno,
mate your in wauchope! i cant believe my luck, were basically neighbors. I'll definately take you up on that. can you PM me your phone number or address and we can catch up. you can check out my 4 speed $600 liberty and have a laugh!
(4th gears gone and 3rd jumps out-came with a spare box in the back)!
Post by El_Freddo » Fri Feb 10, 2012 9:05 pm
hypoman wrote:(4th gears gone and 3rd jumps out-came with a spare box in the back)!
If you've got all those L series at the farm hypo, I'd suggest that you check out this thread: L series low range into EJ dual range gearbox.
Do that then drop the new box in to the liberty ;)
