ea81 engine problems???
ausbrumby
Post by ausbrumby » Tue Feb 07, 2012 8:29 pm
i just bought a 92 brumby with a weber carb, and im not sure whats wrong with it, it starts well but when i turn it off it runs on for a bit longer (like 5 seconds) any ideas what it would be?
Post by El_Freddo » Tue Feb 07, 2012 8:38 pm
It's running too rich and is "dieseling" on shut off - also known as running on. It's caused by the carbon deposits on the pistons and the compression chamber heating and creating an ember that ignites the fuel mixture. When this happens the engine sound really unhealthy. To rid you of this problem you might need to re-tune the carb and some engine cleaner/fuel additive stuff might help clean it out.
The other thing it could be is a dodgy ignition switch that is remaining on for a couple of seconds after you've turned it off - sounds stupid but my L series does it with the accessories from time to time.
thunder039
Post by thunder039 » Tue Feb 07, 2012 9:32 pm
ypu would think being carby it would be more likely needing tuned
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by RSR 555 » Wed Feb 08, 2012 5:11 am
Yep.. sounds like the anti-dieseling switch is missing from your weber.. what model/year weber is it?
Venom
Post by Venom » Wed Feb 08, 2012 6:15 am
My weber doesn't have the anti deiseling switch. once i got the weber tuned and put a can of u.e.c through the car i had no problems with run on.
Sent from my GT-I9100T using Tapatalk
Post by steptoe » Wed Feb 08, 2012 7:32 am
idle speed is the first thing to check and adjust (and tell us what you got)
ausbrumby
Post by ausbrumby » Thu Feb 09, 2012 7:33 pm
I'm not sure what model carby it is, but I will tune it up and get some engine cleaner, mickle appreciate your help guys
Post by RSR 555 » Fri Feb 10, 2012 10:11 am
Oh.. Ok.. so if no anti-dieseling solinoid then a good clean and check idle rpm will be good. If still no good then I'd check that the jet sizes are correct.
