Roof rack tool
Roof rack tool
The L series has those Subaru (ROLA) roof racks fitted.
They also have anti theft bolts attaching them and I did not get a spanner to take them off which is what I now have to do to check for rust and clean the gutter and roof.
The removal tool looks like a 5mm Allen key but it would be a key with a hole drilled into the end of it to fit the lug in the attachment bolt.
Anyone know where to get a removal tool of this type. ?
yeh a roof rack retailer will stock them.
otherwise one of them cheap tool kits with a bajillion pieces normally have one in there.
Yeah.. star torx bit with security pin. Like Alex said, one of those cheap set of odds and sods from SPA will do the trick.
- d_generate
Dick Smith sell them in a nifty little kit with all the weird little tools in it that companies use to stop you opening their components, I've found it handy a few times.
Problem sorted.
Initially I found a low quality 5mm allen key, put it into a lathe, centre drilled the end and then drilled a 3mm hole into the end of the key in about 5mm deep.
You need a low quality key as something like an Unbreako (spelling) is fairly hard to drill whereas a low quality key is easly to machine.
This worked a treat till today when up at the wreckers I found an original key in the ashtray of a 92 model L series wagon. All good
Gotta hate that but always good to have a spareCliff R wrote:Problem sorted.
I got mine from a $2 shopAlex wrote:yeh a roof rack retailer will stock them.
Bloody Murphy's Law again!Cliff R wrote:Problem sorted.
