Auto Electrician
Richie-Rich
Auto Electrician
Post by Richie-Rich » Sat Dec 10, 2011 9:56 am
Hi,
My indicators have decided to no longer work.
Chasing an recommended shop, or the name of the Aus Subie member who does home calls.
Rich
Post by sven '2' » Sat Dec 10, 2011 12:28 pm
you are in luck
SuBaRiNo (Dave) on here
Someone in WA will have is mobile
SuBaRiNo
Post by SuBaRiNo » Sat Dec 10, 2011 2:43 pm
Sorry mate... i would be able to help you but i am up to my ears with people wanting Subi work done before christmas and i have had to tell them all i can't help till next year. Even my Monday to Friday work is not excepting any more work this year.
Dave
Post by steptoe » Sat Dec 10, 2011 9:47 pm
So let's go the remote diagnostic route......
what model??
My 84 Brumby suddenly had no indicators at all no glow, no blink - water got into blink unit from leaky windscreen and zzzt - new one fixed it.
If you have a towbar with a plug, check it, check your fuses, check each bulb works by remove and test on battery and come back......
SuBaRiNo
Post by SuBaRiNo » Sun Dec 11, 2011 1:54 am
Also common is the hazard switch playing up. Give it a wiggle and click it on and off a few times.
Dave
Post by RSR 555 » Sun Dec 11, 2011 10:21 am
Hey Rich, just give me a call when you're free and we'll try and work it out.
Richie-Rich
Post by Richie-Rich » Sun Dec 11, 2011 2:51 pm
Thanks Paul.
Expect a call on Tuesday, I have plans I wish to discuss.
Also boys, 97 Forester. About a week ago the indicator stopped indicating and just displayed a solid light, no flashing. Then suddenly id stopped working all together. The globes are fine as the immobiliser still makes the lights flash, I'm guessing i have a loose wire in the stalk.
Rej
Post by RSR 555 » Sun Dec 11, 2011 6:13 pm
Richie-Rich wrote:Thanks Paul.
Rej
I'll be around.. maybe even at the shop :)
I'm thinking Immobilizer off hand.. have you got an aftermarket one fitted?
Post by sven '2' » Sun Dec 11, 2011 6:41 pm
SuBaRiNo wrote:Sorry mate... i would be able to help you but i am up to my ears with people wanting Subi work done before christmas and i have had to tell them all i can't help till next year. Even my Monday to Friday work is not excepting any more work this year.
Dave
Oh well.
Good for Dave (good position to be in!), bad for RR - sounds like you'll be well sorted presently.
SuBaRiNo
Post by SuBaRiNo » Sun Dec 11, 2011 11:46 pm
Unlikely to be imobiliser. Sounds like a flasher relay fault to me. Try the hazard lights and see if the indicators flash with them. I forget if the indicator flasher relay is the same as the hazard flasher relay on that model.
Dave
Post by RSR 555 » Mon Dec 12, 2011 4:17 pm
SuBaRiNo wrote:Unlikely to be imobiliser. Sounds like a flasher relay fault to me. Try the hazard lights and see if the indicators flash with them. I forget if the indicator flasher relay is the same as the hazard flasher relay on that model.
Dave
Cheers for the heads up Davo.. I'll check that out tomoz.
Post by El_Freddo » Mon Dec 12, 2011 6:18 pm
Outsourcing to Paul now Dave? :twisted:
Post by RSR 555 » Wed Dec 14, 2011 9:37 am
God hope not.. I have enough sh*t to do myself. Dave can keep the electrical stuff !!
Return to “Western Australia”
