Subaru lift
Subarubrumbyfan1991
Subaru lift
Post by Subarubrumbyfan1991 » Mon Nov 21, 2011 8:38 pm
i have a 91 subaru brumby, and i got given a 2 inch body lift to put in. I was wondering if anyone knew of a sheet of fitting instructions or something like that.
i could do it myslef without these instructions as i have a vague idea, but it would save so much time and hassle if i could find a diagram or some instructions.
if anyone could help that would be much appreciated.
Thanks, josh
Post by El_Freddo » Mon Nov 21, 2011 9:47 pm
G'day Josh,
Have a go at using the search function. This has been covered many times.
It's pretty simple though - work out where the parts go, get the subi sorted with chocks to secure it from moving, then using a couple of jacks install some jack stands on an area that's not going to be fitted with lift blocks - eg the floor section of the chassis rail.
Then use the jacks to hold the weight of the component that is going to be lowered for the lift blocks to fit in. Remove one bolt if there are several for that component, place in one of the lift bolts, remove the rest of the non-lift bolts and carefully lower the jacks and the given component.
Place in the lift blocks and the lift bolts, then do the same for the first lift bolt that was used to lower the suspension component.
Once you've got everything lowered make sure you tension everything as it should be. Then check it after a day or two then a week after again.
Other things to look out for are:
> Radiator hoses may need to be lengthened, including the heater hoses
> Speedo cable may need to be lengthened, at least watch it to make sure you're not snagging it on something as you lower the engine crossmember or the gearbox crossmember
> Brake hoses may need attention
> Exhaust may need some modifications or to be dropped then re-fitted after the lift is in
I think that's about it from the top of my head.
Post by RSR 555 » Tue Nov 22, 2011 10:39 am
There's a good pic with some details (from TOONGA) on this page...
showthread.php?t=20921&page=2
ashleyn
Post by ashleyn » Tue Nov 22, 2011 12:03 pm
I've recently done it, search for "Brumby Lift kit first time" where I've posted step by step instructions plus a few tip and gotchas.
Post by TOONGA » Tue Nov 22, 2011 1:34 pm
showthread.php?t=20061
there you go :)
Post by NachaLuva » Tue Nov 22, 2011 1:57 pm
Good luck, let us know how you go, esp with photos if you can...
Post by TOONGA » Tue Nov 22, 2011 2:32 pm
RSR 555 wrote:There's a good pic with some details (from TOONGA) on this page...
remember that this is a kit for an "L" series so it has a couple of differences.
but still it can be used as a basic guide.
Subarubrumbyfan1991
Post by Subarubrumbyfan1991 » Tue Dec 06, 2011 7:07 pm
thanks for all the help guys :) i have brake hose extensions to suit and the speedo will need correcting as i sm putting 14" rims on as they come with a wider range of tyres, if anyone is selling some for cheap around the sunshine coast area im happy to buy them :) doesnt matter the colour, ill post some pics up when im done :)
Post by TOONGA » Tue Dec 06, 2011 7:27 pm
15 inch rims on gumtree in QLD not sure if they are near you. (ad is still up anyway)
http://qld.gumtree.com.au/c-Cars-Vehicl ... Z335777505
Subarubrumbyfan1991
Post by Subarubrumbyfan1991 » Tue Dec 06, 2011 7:45 pm
good rims, but too big, i'm only after 14's, less hassle with the speedo. cheers josh
My brumby :) 91 is amazing, first car and no doubt gonna be my last :D
future plans include 2" lift
14" rims
a/t's
respray
race seats
roll bar
decent spotties
LED lighting inside
Webber carby
extractors with 2 1/2" straight through exhaust
few more ideas but dont want to bore everyone lol
