Brumby/EA81 almost stalling at idle
theconcierge
Post by theconcierge » Tue Nov 08, 2011 3:44 pm
hi all
So my Brumby has always run like a dream. Haven't driven it too much in the last couple of months, but it seems to have developed a idle problem over the last couple of weeks. On start up and at idle it sounds and feels like it is going to stall. When driving it is 100%, it's just when it's at idle.
I have taken a quick video - I have the air cover off ( this made no difference )
http://www.youtube.com/watchv=4hjNKyDK6 ... ata_player
Any ideas what I should start looking at ( I have a very basic knowledge on cars )
revmax
Post by revmax » Tue Nov 08, 2011 3:46 pm
youtube link does not work
theconcierge
Post by theconcierge » Tue Nov 08, 2011 3:46 pm
Post by El_Freddo » Tue Nov 08, 2011 4:24 pm
Without viewing the video I'd be checking all of your vacuum hoses to make sure they're all still connected. It will take one hose to slip off and you'll have starting issues, idle issues and it won't run very well either.
The other thing to check is your spark plugs and leads - if one spark is down you'll be on three cylinders until you pick the revs up.
All the best
Post by Silverbullet » Tue Nov 08, 2011 5:15 pm
+1 for vacuum leak, I had a small one and mine idled like that but when driving it was barely there. Also plugs and leads, I've had a plug look like new but was broken internally.
Failing that you could always give the idle speed screw a little tweak, although it wouldn't solve why the engine has suddenly developed this problem.
theconcierge
Post by theconcierge » Tue Nov 08, 2011 5:57 pm
Thanks guys - how many vacuum hoses are there?
Brumby91
Post by Brumby91 » Tue Nov 08, 2011 7:38 pm
theconcierge wrote:Thanks guys - how many vacuum hoses are there?
Not many, just the same amount of people with the last name "Chang" in a Chineses white pages! :-D
Post by steptoe » Wed Nov 09, 2011 5:32 pm
Your Brumby has just read you intend to sell.....
an amazing fix can be to spray same carby cleaner down the throat of carby while running, comes up nice and clean, washes out gummy crap from all the orifices and bleeder jets etc
Post by Silverbullet » Wed Nov 09, 2011 5:35 pm
Depends more how old the engine/manifold is. All my engines have been 83' or before and have only had 1 or two vacuum outlets. I'm assuming this Brumby is alot later in which case there's a few :p
FROG
Post by FROG » Wed Nov 09, 2011 5:57 pm
Silverbullet wrote:Depends more how old the engine/manifold is. All my engines have been 83' or before and have only had 1 or two vacuum outlets. I'm assuming this Brumby is alot later in which case there's a few :p
one million precisely :-(
Post by TOONGA » Wed Nov 09, 2011 6:17 pm
mine is an 89 brumby and from the look of your aircleaner they put in more vacuum lines
this is a few shots of my carby before the motor was replaced
it may help
Post by TOONGA » Wed Nov 09, 2011 6:18 pm
and some more because I cannot put 10 images in a post
