MY/Brum - no tickers, no hazards - zip
Post by steptoe » Sun Oct 30, 2011 12:13 pm
Jumped in the Brum this morning and off I go, took a while to register the tickers were not ticking nor even lighting up!! :(
Checked the hazards, nothin there either. They have worked perfectly for years, even as recent as yesterday - which was wet, and the screen rubber has an odd leak due to shrinking rubbers, and the blink unit is just wghere you might imagine a windscreen leak would go......pulls out the unit Bosch electronic P1234, cover off and there is a definite rusty tinge to things, corrosion on the legs of the IC.
I suspected it was worse - like the switch combo unit due to no lights at all. never had a flasher unit not glow the lights. The Brumby and MY use the one flasher unit for both tickers and hazards. Chucked in a new Narva 3 pin P/N 68238BL , states a max load of 6 x 21W + 5W
Oh, had forgot what control plus does on the keyboard 'til now
All good
Brumby Kid
Post by Brumby Kid » Sun Oct 30, 2011 4:19 pm
What if your indicators are both flashing, but really fast?
All lights are working etc. It is a Brumby
Dads Car: 02 Impreza WRX STi
Post by El_Freddo » Mon Oct 31, 2011 12:39 am
Brumby Kid wrote:What if your indicators are both flashing, but really fast?
You've either got a globe that's blown or you're running globes that are too low wattage for the blinker box (for the want of a better name for it) - same goes if you're running LEDs, you'll need an LED blinker box to give the appropriate flashing time ;)
Clear as mud?
mud_king91
Post by mud_king91 » Mon Oct 31, 2011 4:46 am
or it could be a fuse as i learnt with the mercedes yesterday turns out all the brokens were just not working because some genius pulled out the fuses :S
GROWING OLD IS COMPULSORY... GROWING UP IS OPTIONAL
WTB
BRUMBY, FORESTER prefferably GT
Brumby Kid
Post by Brumby Kid » Mon Oct 31, 2011 7:09 am
Well i dont have the back lights hooked up atm so it could be that, otherwise yes it is pretty clear, crystal infact.
Post by steptoe » Mon Oct 31, 2011 7:13 am
back lights not hooked up is the same as a bulb not working ! (slap)
Brumby Kid
Post by Brumby Kid » Mon Oct 31, 2011 7:48 am
steptoe wrote:back lights not hooked up is the same as a bulb not working ! (slap)
Bahahahahahaha, im a smart one! :rolleyes:
Yes i think i need to be slapped to get some sense into me.
Post by NachaLuva » Mon Oct 31, 2011 10:58 pm
Brumby Kid wrote:Bahahahahahaha, im a smart one! :rolleyes:
Sounds like you mite enjoy it lol :rolleyes:
Smash1911
Post by Smash1911 » Mon Oct 31, 2011 11:25 pm
The flasher unit requires a certain amount of electrical load to flash at the correct speed. If LED replacement lights are fitted you can just fit resisters in each circuit to simulate a normal globe.
Post by Silverbullet » Tue Nov 01, 2011 6:12 pm
Jonno when you said tickers I thought you meant the tickers in the engine bay :rolleyes:
My indicators work fine but if I press the hazards switch only one side ticks :confused:
Post by steptoe » Wed Nov 02, 2011 7:35 am
oh ! And you thought a flash can that fixed it was a bit like Peter Brock and his Energy Polariser :D
the one sided thing may likely be in the combo switch tickers, high beam on your steering column
Post by Silverbullet » Wed Nov 02, 2011 5:27 pm
steptoe wrote:the one sided thing may likely be in the combo switch tickers, high beam on your steering column
Would make sense, if I flick the indicator stalk forwards for permanent high beam, all lights turn off...bit scary at night! :eek:
Pulling it backwards they come on fine though.
