L Series: is there anything I should be greasing/lubricating?
fishboy
Post by fishboy » Sun Oct 09, 2011 2:17 pm
Besides various door hinges, latches, and foot pedals, there doesn't seem to be anything much in the workshop manual about what/where to grease on an L Series (1991). Do cars like this not require grease/lube anywhere to keep them running smoothly??
Post by steptoe » Sun Oct 09, 2011 6:05 pm
Nipples on tail shaft unis ?? MY had them, and if L do, I have not greased mine for tht long I can't remember - that's bad......
Post by NachaLuva » Sun Oct 09, 2011 6:12 pm
steptoe wrote:Nipples on tail shaft unis ?? MY had them, and if L do, I have not greased mine for tht long I can't remember - that's bad......
You always have to make sure you grease your nipples...thoroughly! :p
Venom
Post by Venom » Mon Oct 10, 2011 8:03 am
You can buy greasable tie rod ends. Tail shaft uni's are not greaseable from factory (from the ones i've seen anyway), but replacement uni's probably are. Thats about all i can think of.
Post by El_Freddo » Mon Oct 10, 2011 12:12 pm
There's not one grease nipple on my L series - and I've been over my car enough to know!
So you're in the clear. Just keep the coolant and oil where it needs to be and you'll be sweet!
fishboy
Post by fishboy » Tue Oct 11, 2011 8:23 pm
Ah, good stuff. This I do!
