DIY lift kit
mud_king91
DIY lift kit
Post by mud_king91 » Fri Oct 07, 2011 8:19 pm
just thinking in regards to a diy lift kit what would be safer i understand for a 2" its just 50x50 box but what if for instance i want a 6" what would be better to use 150x50x2.5 or 2 75x50x4.0 bolted together ?
rtcb65
Post by rtcb65 » Fri Oct 07, 2011 9:25 pm
mud_king91 wrote:just thinking in regards to a diy lift kit what would be safer i understand for a 2" its just 50x50 box but what if for instance i want a 6" what would be better to use 150x50x2.5 or 2 75x50x4.0 bolted together ?
Only 2 inch is legal in most states. But dont forget if going if going any size lift , you have to get the right off set on the strut tops. it not just 2 plates and a piece of metal in between.
rtcb65
Redneck Rick.
mud_king91
Post by mud_king91 » Fri Oct 07, 2011 9:36 pm
yea its cheap fun once it gets defected it,ll get a ground up rebuild or race car,d
spike
Post by spike » Sun Oct 09, 2011 1:05 pm
mud_king91 wrote:yea its cheap fun once it gets defected it,ll get a ground up rebuild or race car,d
a couple of people have thought about DIY kits, i was looking at making the ones paul at subarwreck sells. Not worth it, 200 in steel, nearly 200 in bolts and the parts got sold for 700 so yeahs not enought mark up for me to make a dollar.
But the point is its 400$ for a kit and that was just a 2 inch.
the 6 inch kits are welded on instead of bolted.
mud_king91
Post by mud_king91 » Sun Oct 09, 2011 1:28 pm
maybe i should use my brain for once and stick to 2 inch and a set of 14,s like everyone else
GROWING OLD IS COMPULSORY... GROWING UP IS OPTIONAL
WTB
BRUMBY, FORESTER prefferably GT
Post by AndrewT » Sun Oct 09, 2011 11:36 pm
If you make a lift kit make it in single pieces, not smaller lift kits bolted together to make larger.
Post by El_Freddo » Mon Oct 10, 2011 12:35 pm
AndrewT wrote:If you make a lift kit make it in single pieces, not smaller lift kits bolted together to make larger.
I think someone has bolted two 2 inch kits together before, you'd know them wouldn't you AndyT?
I was going to DIY my lift kit, then I picked up a lift kit for $450, came with a free L series!
:mrgreen:
Tweety
Post by Tweety » Mon Oct 10, 2011 1:06 pm
Not much mark up (profit) in lift kits.
But with some of our friends on this forum like Bennie there would be a market for oxygen masks.
Post by El_Freddo » Mon Oct 10, 2011 2:34 pm
Tweety wrote:But with some of our friends on this forum like Bennie there would be a market for oxygen masks.
Nah mate, I'm high up enough for fresh air!!
:twisted:
spike
Post by spike » Mon Oct 10, 2011 7:11 pm
check out the look of andrew Ts awesome kit and build. Id suggest 4 inches, different but yeah, or the 2 inches.
mud_king91
Post by mud_king91 » Mon Oct 10, 2011 7:27 pm
well the missus has demanded that we buy a house in the next year or two which requires credit rating meaning ill have to get a small loan ( credit rating ) and she also demanded i buy a ute so im putting two and two together haha i reckon a 4 inch would be sweet iv got some 100x50 up at the inlaws vineyard i think... if not the grandfather inlaw will have some at his i can borrow :P
WTB
mud_king91
Post by mud_king91 » Wed Oct 19, 2011 5:59 pm
would nylon blocks be safe... not for the struts of course but everywhere else should be fine shouldnt it ?
WTB
d_generate
Post by d_generate » Wed Oct 19, 2011 6:46 pm
I'm using nylon in a couple of places, the bread board type of stuff, it came off the runners on a skip bin truck, 2 x 65mm blocks under the front of the trailing arms & solid alloy everywhere else, it seems to be holding up quite well but I'll be ripping them out soon as my wheels are too far back with the 1" extension on the arms.
mud_king91
Post by mud_king91 » Wed Oct 19, 2011 7:59 pm
well iv known it be pretty good stuff i used it once to makes a silencer for my .22 (worked for 2 shots ) so it justifiable that a coke bottle and polestyrene works better but i figure its durable and cheap if you know where to look not to mention it allows me to do a safe one piece 4-6" lift
WTB
d_generate
Post by d_generate » Wed Oct 19, 2011 10:48 pm
Yeah, you'd just need to go around and nip things up a couple of times after use to make sure it's not collapsing if using just the nylon, I remember when I ripped the body off my 60 series Landcruiser it just sat on 10 small rubber blocks with a steel tube going through them, the tube may be worth a thought, the whole lot will cost bugger all & I think it would work well.
mud_king91
Post by mud_king91 » Thu Oct 20, 2011 7:44 am
i was thinking of that... id have to use crush tube anyway unless i went solid alloy
WTB
spike
Post by spike » Fri Oct 21, 2011 9:39 pm
d_generate wrote:Yeah, you'd just need to go around and nip things up a couple of times after use to make sure it's not collapsing if using just the nylon, I remember when I ripped the body off my 60 series Landcruiser it just sat on 10 small rubber blocks with a steel tube going through them, the tube may be worth a thought, the whole lot will cost bugger all & I think it would work well.
im sure you know but its not the blocks that cost much its the bolts to hold them
mud_king91
Post by mud_king91 » Fri Oct 21, 2011 9:59 pm
yea sorta figured after my experience with an excavator shearing drive wheel bolts.... $200 for a couple of short but super thick and supposedly strong bolts... i was originally thinking a long threaded bar and just make my own out of that
WTB
d_generate
Post by d_generate » Fri Oct 21, 2011 11:03 pm
Having ripped apart about 3 Subi's for parts I have a box full of bolts though the longer ones have pretty much all gone, I think I bought about 10 ht bolts all up but 6 of them will be coming out soon ..... possibly all of them as I put 50mm blocks where the ALK would go too, it's amazing how you can swap a lot of the long bolts you take out of one place and replace the shorter ones with them on the Impreza/Liberty.
mud_king91
Post by mud_king91 » Sat Oct 22, 2011 8:30 am
d_generate wrote:Having ripped apart about 3 Subi's for parts I have a box full of bolts though the longer ones have pretty much all gone, I think I bought about 10 ht bolts all up but 6 of them will be coming out soon ..... possibly all of them as I put 50mm blocks where the ALK would go too, it's amazing how you can swap a lot of the long bolts you take out of one place and replace the shorter ones with them on the Impreza/Liberty.
hahahahahahaahhaha i think ill just pay the price and get some high tensile ones atleast i know they,ll with hold anything
WTB
