Lift Kit Help
- Brumby Kid
Lift Kit Help
My mate told me this and i just wanted to clarify as he doesn't always know what he is talking about:rolleyes:. Ok so, he said a lift kit just lifted the body ie. panels. I thought it lifted everything, the chasy as well. I would have thought that they would lift everything or people would just get a suspension lift.
Is it worth bothering with a lift kit or should i get a suspension lift?
Thanks Cam
Thanks Cam
- mud_king91
- Brumby Kid
Would this be the same as a suspension lift? Would the driveline be overexposed when offroading?
There is a Full Body Lift which will lift the whole body but leave the engine, gearbox, diffs, etc... at stock height.
Then there is a strut lift which lifts everything except the wheels. All the body, diffs, gearbox, drivetrain, engine, sumpguard.
I went for a strutlift personally because I bashed my sump in and was damaging the underside too much
But with the combination of both you can go more than 3" compared to just one or the other.
Taza
Taza
- Brumby Kid
Prices? Sounds nasty, yeah i think the max is 2" but with suspension you can go more. I would probs only go the body unless it wasn't too expensive and worth the strut lift.
Cam
Cam
- mud_king91
True what mud_king91 said. The cheapest and easiest way to lift your brumby would be using 2" strut blocks which would cost you about $350-400 also if you put them in yourself or with the help of others rather than going to a shop.
Also i might add anymore than 2" (50mm) is illegal without an engineering certificate and your vehicle can be yellow stickered.
Taza
Taza
A 100mm may be true but when using lift blocks by themselves you are allowed no more than 50mm lift blocks (according to national standards). But in saying that I have 50mm lift blocks in my outback and all legal plus once you do that it is possible to fit decent sized tyres on, And one of my brumbies has a three inch kit and forrestor wheels and tyres but has more clearence than my dads hilux!
87 targa brumby (Neglected),
+ others.
+ others.
- mud_king91
- Brumby Kid
Ok so 2" is fine? then engineering certificate which costs the earth? Can i raise my suspension as well without A certificate? I hate the sa laws!
- Green_eyed_liberty
the reason for the "body lift" is so you can fit bigger tires under the guards without too much trimming. that's where most brumbys get there ground clearance is through bigger wheels/tires
and keep in mind the heigher you go suspension wise, the more camber you will get (bad camber.. not hella flush camber!)
If you are talking about a brumby, it is the easiest to do. You just put a lift kit in it , which lifts the body( more ground clearance under the body). Then you put 14 inch rims and tires on, with something like 27 inch tires. Then you have body and drive train clearance . Price wise for a good lift kit , from say Crossbred Performance is around $450 or so.
As for strut lift , it cant be done in a brumby, as there no struts in the back. With a lift kit as said above , there is no problem with wheel alignment or camber, due to none of it is touched.
rtcb65
Redneck Rick.
Redneck Rick.
- Brumby Kid
Sounds Good,rtcb65 wrote:If you are talking about a brumby, it is the easiest to do. You just put a lift kit in it , which lifts the body( more ground clearance under the body). Then you put 14 inch rims and tires on, with something like 27 inch tires. Then you have body and drive train clearance . Price wise for a good lift kit , from say Crossbred Performance is around $450 or so.
thats what I want is a higher car with more ground clearance. I think i have 14" sunnys (will double check tomorrow) but with standard road tyres. What does a lift kit actually look like? Yes i know im young and dumb, so i sought of have an excuse.
Cheers Cam
If you go to the Crossbred Performance web site , it will show you what a lift kit looks like. Just follow the buttons ( ie , products ) .
rtcb65
Redneck Rick.
Redneck Rick.
Could you do a coilover conversion in the rear and front of a brumby?rtcb65 wrote:If you are talking about a brumby, it is the easiest to do. You just put a lift kit in it , which lifts the body( more ground clearance under the body). Then you put 14 inch rims and tires on, with something like 27 inch tires. Then you have body and drive train clearance . Price wise for a good lift kit , from say Crossbred Performance is around $450 or so.
Is there really no way to do a strut lift with a bit of work?
What about landcruiser (fj40/45) struts, apparently they might fit?
-97 Landcruiser
-97 Landcruiser
- Brumby Kid
So I'm looking for a 2" lift kit. Where Would people reccomend buying from?
Crossbred performance, subtle solutions
Steve at rising sun?
Just after a list so that I can get the best quote.
Cheers Cam
Cheers Cam
- d_generate
FJ40/45 had leaf springs and shock absorbers front and rear.B00sting wrote:Could you do a coilover conversion in the rear and front of a brumby?
- mud_king91
I don't know if Steve at rising sun does them... Crossbred produce a great product, Venom's running a two inch full body lift in his H6 liberty.Brumby Kid wrote:So I'm looking for a 2" lift kit. Where Would people reccomend buying from?
Or you could try emailing the crew here: [email protected] and hopefully they'll be able to get back to you. I think a lot of members have forgotten that the BYB crew make lift kits. From memory it was Subi Wan Kenobi that was building them, I'm not sure what the status is these day, hopefully you'll find out
