Toyo Open Country or Cooper CS4
My 2 gen outback is due for new rubber. I currently have Falken t110s on it, I'm currently tossing up between Cooper CS4 or Toyo Open Country H/T. Anyone want to offer thoughts on which is the better tire? Lots of bitumen use, lots of gravel and very occasional mud.
- mud_king91
toyo.
cooper make shit tyres. All their 4x4 tyres chip and lose big chunks, thats enough for me to not buy any tyre they make.
I'v only had Toyo ROAD tyres before but was very happy with them.
Have you thought about Yokihama Geolanders? Bob Jane has a special at the moment...buy 4 & get $100 cashback. I was gonna wait til i did my suspension but i think i'll be doing that 1st. Only thing i cant decide is H/T or A/T....
The Geolandar G900's certainly do... I've moved from them to the A/T-S all terrains and they are very good.foxx510 wrote:I thought the Geolanders had a terrible reputation, if only for their squeeliness....
Never had any experience with Coopers, but Toyo's are pretty good as well, IMO.
Pedro.
GONE
The Geolander A/T is bit more aggressive...have a look at the Geolander H/T. Its more of a highway tyre.foxx510 wrote:The Geolander at/s looks pretty good and gets decent reviews. I think it's a bit overkill for the roads I mainly use, I just don't do enough mud driving to need that aggressive a tread pattern. Will consider it if that changes though. Thanks
I think the code is:
Highway Terrain = H/T;
All Terrain = A/T.
I cant decide which to go for but it will be 1 of those 2
I have considered those two tyres and shared my Internet reviews findings in another thread, showthread.php?t=15299foxx510 wrote:I'm currently tossing up between Cooper CS4 or Toyo Open Country H/T.
Cooper CS4 is a T speed rated tyre for passenger cars. Toyo OC H/T is an H speed rated tyre for 4WD. The "passenger" part means that Cooper will handle better when changing the lines or turning around the roundabouts, even if it has a less speed rating (generally, higher speed rated tyres have firmer sidewalls which results in better handling).
For lots of gravel driving, when the tyre is quick to wear, a tyre with harder rubber is required. Cooper has a harder rubber (this is also why it has a lower speed rating). It is rated for 100k km, and warranty for that is given, but only in the USA. The Toyo tyre seems to be made of a softer rubber, and would wear quicker.
Both passenger tyres and Highway-Terrain 4WD tyres are made with 2 plys. This means the resistance to puncture is the same.
Both tyres have a generous amount of siping, so that the grip in wet weather and on gravel should be equally good.
For mud, both tyres would perform equally, and the performance would be bad.
Just got some Yoki Geolander AT-S...look very nice lol
Cant believe how deep the tread is! They look very serious....for a standard size that is lol
Cant wait to test em out in Robe/ LDNP
Only thing is when i did a test drive after, there was some vibration under braking coming through the steering wheel! Any suggestions?
Yeah as soon as i noticed the vibrations i pulled over & ckecked em. Couple were slightly loose but nothing major. Pressure in 3 wheels was 38.5, other 36.0 warm. So i set em all to 36.0.
Had roadworthy 2mths ago & had new pads all round. Is there anything he may not have tightened up properly?
Weird thing is only noticed it with the new tyres...
No ABSvalerian wrote:This might be ABS activating. The All-Terrain tyres are more slippery in some conditions, so that ABS brakes activate earlier.
seems to have disappeared
I wonder if it was just tyres bedding in...never had that happen before tho...
i've got yoki geo AT/s and i'm very happy with them
altho, i now have cut 2 sidewalls
but thats with very low psi's on rocks, as i was going on tracks with rocks and boggy sand didnt have much choice, bugger!
and make sure you rotate and balance regularly!!
i run them normally around 38 for road,
20 for rocks/corrugations,
10 for sand,
lowest i've been is 8psi on sand including full lock-lock steering up n over dunes and around tracks.
based on coopers advertising i almost bought a pair, but after hearing feedback from owners, not that many said they would buy them again, where as i noticed more people would happily buy the yoki geo AT/s second time around.
i work in a store that sees lost of 4wdrivers and outdoor enthusiasts, and get to hear a fair bit from there aswell,
yoki's are popular in my 4wd club also, some like the BFG's as a cheaper alternative?
10 for sand,
"SUUBMARINE"
20" LED Front Light Bar
How would you compare the handling of the car equipped with the A/T tyres, with that of an H/T tyre ?longy99gt wrote:i've got yoki geo AT/s and i'm very happy with them
Here is why I am asking. I noticed there was a newly-released tyre Bridgestone Dueler A/T D697, a replacement of D694. I currently run a passenger tyre on my Subaru Outback, but I would like to put the D697 tyre with its aggressive look. But I do not want the handling and cornering capability to suffer. I had found an H/T tyre of a T speed rating was too squishy and let the car roll when turning. Now I have a passenger tyre with an H speed rating, and the car is solid when turning around corner. The T speed tyre had a soft sidewall, and the H speed tyre had a firm sidewall. The D697 tyre has an S speed rating, thus it should have a very soft sidewall. However, I hope the manufacturer made the sidewall firm, so that it would resist puncturing when off-road...
i havent driven on HT's for a while now,
i do know their sidewalls are much softer,
been on ATR's for a solid year now,
"SUUBMARINE"
