One of Australia's original and top performing Subaru sites. Come and have a look and find out why so many people enjoy this site.***ONLINE SINCE SEPTEMBER 2018*** site address: www.ausubaru.com.au
Hey guys as most of you know i'm doing the EJ22 conversion at the moment,
just after the last things, one being the radiator, I've found a place but they need me to supply copper brass tanks but I've got plastic ones, not even guy has them haha.
but any way my question is does anyone have sum lying around any where??
Are you trying to replace your 32mm radiator ports with 38mm EJ ones? You can just get flexible hoses with different sized ends, or cut the end off an old 32mm hose and use that as a sleeve inside the 38mm hose.
But if you're keen, do as Toonga says. Start by looking at MYs. Any rad shop worth its salt really should be able to supply end tanks.
Dane.
Gleno's L series single core aluminium rad with plastic tanks work a treat and never looks like getting hot. The best thing about the single core (other than the cooling properties of alloy) is that it doesn't take up too much room and will allow you to fit better cooling fans.
