Ej20T head gaskets help
dj fbi
Post by dj fbi » Wed Aug 24, 2011 5:44 pm
I recently bought a ej20T motor on ebay, and i am now rebuilding it and putting it into my touring wagon. The guy i bought it of said it was a 98 motor but he was not to sure, so any way i have take the heads of and taken them in to the shop to get shaved and checked, now i need to order new gaskets but i dont know the year model so not sure which ones to get? and also for the timing belt kit, the heads on it with the shim and bucket style lifters if that helps and the numbers on the block are AB and then four number, i dont have the motor here. Are the heads all the same? any help would be great, Cheers
[SIGPIC][/SIGPIC]1991 L series touring wagon, ea82t,tdo4,tmic,vl 380cc injectors,adjustable fuel pressure regulator,pod,5 speed rs turbo awd gear box,lsd diff,3 inch zorst to big ass cannon ect.. my baby
Brumby Kid
Post by Brumby Kid » Wed Aug 24, 2011 7:56 pm
There should be the same for all ej20T's. It shouldn't change. If not Check the engines VIN Number, this will help you with everything. Just tell the guy in the shop what your after, and for this VIN, and it should be all good.
I go to car shops for my brumby, they look up the engine number and or VIN and they can give me the precise part!
Cam
Dads Car: 02 Impreza WRX STi
Post by El_Freddo » Wed Aug 24, 2011 8:12 pm
Brumby Kid wrote:There should be the same for all ej20T's. It shouldn't change. If not Check the engines VIN Number, this will help you with everything. Just tell the guy in the shop what your after, and for this VIN, and it should be all good.
That works well Cam, but I don't think he got the VIN details with the engine - just the engine which could make it painful.
I'd be contacting frog and let him know straight up that you don't have the donor's VIN. If you can work out what the donor vehicle was, try and grab one from someone who's got the matching type of vehicle with the same engine as what you've got headed for your wagon ;)
Brumby Kid
Post by Brumby Kid » Wed Aug 24, 2011 8:38 pm
El_Freddo wrote:I'd be contacting frog and let him know straight up that you don't have the donor's VIN.
Yes Frog would know Bennie send him a message dj fbi:-D
Cam
Brumby Kid
Post by Brumby Kid » Mon Aug 29, 2011 8:47 am
Hows it going? got it sorted yet?
dj fbi
Post by dj fbi » Mon Aug 29, 2011 3:18 pm
I got it sorted i hope.... thats if the oil cap is right, they have the date of the motor under the oil cap. Anyway i have ordered the head gasket kit and timing kit so will find out in the next day or so. I cant wait to drop her in my wagon. :)
Post by Alex » Mon Aug 29, 2011 3:20 pm
EJ20T L-series is so much fun.
damn i want mine back now :(
Post by El_Freddo » Mon Aug 29, 2011 3:38 pm
Alex wrote:damn i want mine back now :(
I gotta say it!
TOLD YOU SO!!
That is all, end hijack
Post by TOONGA » Mon Aug 29, 2011 5:38 pm
best way to work it out is to pull the heads off and measure the bore. then get head gaskets to suit.
H-top
Post by H-top » Mon Aug 29, 2011 5:41 pm
im having the same problem with cam cover gaskets,
no one can match them
H-Top
rolling in
