Hi guys the check engine stardom after I start my 92 Subaru liberty fx wagon 4wd it does
No flash is stays solid it does
Not
Do it all the time and if I turn the engine off and start it aging it will go away it mainly does it when cold any help will be appreciated thanks
Check engine stays on after starting engine
- Brad_Stacey
The light will only illuminate solid if their is any error, You will need to read the error codes to determine the cause. This is when the light will flash the codes.
This is the link to the sticky from the electrical section.
http://www.ausubaru.com.au/showthread.php?t=14372
Once you know what circuit is the problem you can start your search.
Cheers Brad
Cheers Brad
(Great) SUPER Endeavour Rally 2012 - Bring it on!
17 Days, 10,000kms Charleville to Yeppoon via East Arnhem Land (Gove)
http://gercar188.blogspot.com/
https://great.endeavour.com.au/rallies.html
