Have a two year old Panther trike with custom one off roof with sunroof. Has a 1916cc aircooled vW engine at present mated to a type 3 auto.
I decided a while back to convert it to EA81 power. I dont need heaps of power and want economy.
I have secured a compelte EA81 engine that was recoed by its elderly mechanic owner. It was in a '92 Brumby. It will be ready for pick up next week. It had a worn dizzy shaft.
Have purchased a brand new electronic distributor and weber 32/36 carbie as recommended on forums by owners.
I have a few questions even after reading extensively through these pages.
- Are there any "bling" products available. eg chromed rocker covers, pullys at the rear etc.? As you can see the VW engine is shiny and I'd like the Subie one to be also.
- The engine looks cool enough as alloy but if I paint it (block) will that cause issues?
- I havent seen the sump. It would be standard. I have a large sump on my 1916 engine. Will it be lower than this? If it is then it might be too low...what are my alternatives? Are there aftermarket shorter sumps available.? Or how difficult is it to get it shortened?
- The mechanic will fit the weber and dizzy. I will clean the engine and check the tappets etc. What else would you recommend while the engine is out of a vehicle?
PS I suspect I'll get "why didnt you go for an EJ engine". The answer is simpicity among other reasons.
Thanks in advance.
Tweety
