86 xt distributor technical info
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
ClydeVarney
Post by ClydeVarney » Thu Jun 30, 2011 10:20 am
I have a 86 xt mpfi turbo, ea82 motor. I need technical information on the distributor igniter module mounted in the distributor. Wiring diagram, correct hook-up, test procedures, etc. Any and all help will be appreciate
discopotato03
Post by discopotato03 » Sat Jul 02, 2011 10:10 am
Exactly the same as the 1986 L Series RX Turbo EA82T
and as luck would have it I can't find my 86 EFI section manual that covers the distributor you have .
Will look again later , cheers A .
Post by steptoe » Sat Jul 02, 2011 12:32 pm
I am wondering if it is different to our 85/86 RX in the XT
Can you provide a part number from the side of the dizzy or at least does it have a vac can on the side, wires enter at the bottom of dizzy or just below cap? 3 or 4 plugs into the ECU mounted in trunk just below window
Post by steptoe » Sun Jul 21, 2013 9:29 am
and Clyde never came back .....
Post by El_Freddo » Wed Jul 24, 2013 10:59 pm
steptoe wrote:and Clyde never came back .....
At least not to post... He could still be "stalking" - or suffers from short term memory loss :(
Return to “Tech Manual”
