I am desparetly after a auto gearbox to suit a '91-'92 liberty. It needs to be awd with 4.44 ratio diff. The diff in mine has failed but the box is good so I would even be interested in a set of 4.44 ratio gears so I could rebuild it. Any leads would be very helpful.
P.S. why can't I post in the classified section?
4at auto box wanted
- velocityboy
- TOONGA
sorry can't help with the gearbox but the reason you can't post in the classified section is because you are an unsubscribed member.
see here
showthread.php?t=12411
see here
Check out some of your local importers as all imported (JDM spec) turbo Legacys use the 4.44 ratio auto trannys.
