front strut Q
- brumbyrunner
front strut Q
Can anyone confirm the thread on the top of an MY or L series strut is M12x1.75?
No guessing!
This is on the 20mm crome shaft that bolts into the rubber strut top.
I'm away from home and Suby-less.
Oh yes, and I'm back.
No guessing!
Welcome back Brumbyrunner, I was wondering about your very nice long travel struts, how did they work out?
Bad Matt.
Bad Matt.
1989 Subaru WonderBrumby II
- brumbyrunner
51 views and not a single answer to my question
The struts that I put together worked out with 11" of travel compared to 5.5" std. Thats pretty good but after that I was swamped with work and stuff so nothing else was done. The new strut top design too has slowed me down. These are adjustable for camber so that they suit any lift up to 6" and do away with the weak factory one. I had trouble sourceing (?) the female rod ends that I want to use, but I found a new supplier while on holidays that might stock the correct size only I cant remember exactly what it is.
- brumbyrunner
brumbyrunner just so happens I just changed the springs in my L.
The thread is definatley M12 x 1.25, the same as wheel studs!
Checked the My as being the same.
Roger.
Roger.
- brumbyrunner
- BaronVonChickenPants
- brumbyrunner
