Removing lift kit
Removing lift kit
I want to lower my brumby and have discovered when climbing underneath that it has a 2inch lift kit. I rang a shop and they told me its alittle bit more involved than just taking the blocks out. Once the lift kit is removed do i have to replace any parts brake lines, struts ,shocks? etc
im guessing i shouldn't have any issues with other parts breaking on me once the kits removed as it will be at factory height, can anyone confirm?
if anyone is looking for a lift kit ill be more than happy to work a deal out.
cheers steve
0401549683
cheers steve
0401549683
G'day Scuba
What you will need is all the mounting bolts from a non lifted brumby or MY wagon/sedan but must be 4wd ONLY for the moustache bar mounting bolts.
The other things to consider are the steering extension, exhaust if its been modified for the lift and the various hoses such as the radiator and heater hoses. There may be a difference but then again there may not.
As for the brake lines - just make sure they're secured and tucked out of harm's way. The struts etc that you've got will do the job just fine.
You and a mate could do it in a weekend, with someone in the know a day at the most if there's no complications
Hope this helps.
Hope this helps.
- TOONGA
If you do a deal with the person who wants the lift kit you will be able to use their factory bolts etc. the kit from a brumby will fit an MY wagon/sedan/coupe or another brumby it won't fit an L series as the strut tops are different
a word of warning as well make sure every bolt and nut that has to come off has been soaked in some sort of lubricant like CRC, WD40 or RP7. Penetrine or forsch are two of the best Ive ever used but cost a fortune. my older brother swears by a mixture of diesel and twostroke oil mixed together not sure of the ratio but 25:1 would be a good start.
otherwise you will end up with broken bolts in captive nuts or even worse sheared captive nuts.
i could find a home for the lift kit?
my sister has a 1990 brumby that could do with it...
"SUUBMARINE"
20" LED Front Light Bar
You should post up some pics of your brumby. You got one good looking brumby:)
No probs Steve.. good to meet you and hope see your Brumby with the EJ conversion in it one dayscuba wrote:Lift kit is out and has new home. Thanks again Paul done good job
+1guyph_01 wrote:You should post up some pics of your brumby. You got one good looking brumby:)
If only I lived back at home
WA is just too far away. I can send you the standard bolts and you can send me the kit back after you fit them
