L series - outer race
silversubiowner
Post by silversubiowner » Sun May 22, 2011 4:29 pm
Hey all,
How do I get the outer race off the front driveshaft (94 L series wagon)??? :confused:
Cheers all
Silversubiowner
Post by TOONGA » Sun May 22, 2011 5:41 pm
using the steps to remove the front cv shaft you get to the point where you are left with the caliper and rotor in place.
remove these then the bearing will be in view behind the bearing/cv seal you have to either remove the knuckle and press the bearings out or use a drift to knock the bearings out
http://rapidshare.com/files/369419146/1 ... ension.pdf
page 187 in the PDF above
silversubiowner
Driveshaft
Post by silversubiowner » Sun May 22, 2011 7:35 pm
Hey,
Everything has been removed from the driveshaft, except the component (see picture) still attached by a circlip. Any ideas about how to remove this?
Post by TOONGA » Sun May 22, 2011 8:12 pm
sorry I was thinking outer race as in bearings in the hub you need circlip pliers that expand to remove the circlip holding the race on. once that circlip is off the race will slide off the shaft
Post by RSR 555 » Tue May 24, 2011 11:17 am
Edit: sorry didn't see post with pic.. yeah, follow what TOONGA and Phizinza have said but I guess by now you have it sorted?
Phizinza
Post by Phizinza » Tue Jul 05, 2011 9:43 pm
silversubiowner wrote:Hey,
Remove the circlip on the end of the shaft
This is what holds that piece on.
