Identifying a LSD????
skrewd
Post by skrewd » Mon May 16, 2011 6:44 pm
Hey guys, just wondering if theres a way to tell if the R160 diff is a LSD. Is there numbers or markings on there other than the sticker or is it a matter of opening the diff up to see.???
Post by TOONGA » Mon May 16, 2011 7:35 pm
if it has a sticker on it the sticker will state that it is an LSD
you may be able to see through the upper oil level bung but dont hold me to that
littlewhiteute
Post by littlewhiteute » Mon May 16, 2011 8:12 pm
Jack up one rear wheel, select neutral, handbrake off.
If you can turn the wheel easily it's non-lsd.
It should take some effort (breakaway torque) to rotate the wheel if it is an LSD.
Gary ;)
skrewd
Post by skrewd » Tue May 17, 2011 8:44 am
littlewhiteute wrote:Jack up one rear wheel, select neutral, handbrake off.
i might give that a try, i was talking to a bloke yesterday that swears he has one sitting in his shed, but its got nothing on it to say if it is LSD or not
Post by AndrewT » Tue May 17, 2011 11:08 am
If it's sitting in a shed already removed from the car just take the rear housing plate off and look inside, it's only a few bolts, take you 2 mins.
Post by El_Freddo » Sat May 21, 2011 11:55 pm
AndrewT wrote:If it's sitting in a shed already removed from the car just take the rear housing plate off and look inside, it's only a few bolts, take you 2 mins.
And you shouldn't be able to see any spider gears, it should look a bit like a cylinder mounted with a ring gear...
