Hmm... Someone's already done it...
Post by El_Freddo » Wed May 11, 2011 4:21 pm
G'day all.
I post this as I find it interesting, and a little disheartening - I say that as this is the setup I'm in the process of aiming for, while most of its been done before I thought it might have been a first for victoria. Wrong.
Anyway, if anyone has a spare $4-6G to part with here it is
A couple of things I would love to know about this: What lift is used? Body/strut?
The 14 inch rims - how they were made, if the stock centre was taken and welded to a 14 inch ring for the rim, why not use a sunraiser rim for better looks?
And last I'd love to know who did the certification and how much it all cost - if I was looking to buy I would want to see the certification paperwork first.
Now to get back to Ruby's build...
daza
Post by daza » Wed May 11, 2011 4:36 pm
The ad says "Full Body lift", and the 14" rims are standard Peugeots.
Who are you building your car for, you or the spectators?
Build what you want to drive, who cares if it's been done before!
Just have to make your better!
Daza.
:D
ScubyRoo
Post by ScubyRoo » Wed May 11, 2011 5:35 pm
Bah, that hump of junk has nothing on Ruby. Those rims look awful and I'm not a fan of those weird rear tire carriers.
Post by AndrewT » Wed May 11, 2011 7:45 pm
You didn't know that somebody had slapped a lift kit and an EJ in an L series before? :)
Looks like a pretty normal setup to me? You can see a lift block in the last photo.
Yes I wonder what kind of rims they are. Maybe off some kind of Pug or perhaps custom made.
Gearbox setup is interesting. The interior looks like it's an L series box so must have been cracked open to have 4.111 diff put in, rear diff is probably a VLSD one from an early RS unless it's an RX CLSD that's been re-ratio'ed to 4.111. If it is an AWD one then that's obviously quite rare.
skrewd
Post by skrewd » Wed May 11, 2011 8:06 pm
i was only talking to my boss this afternoon about building one of those roof racks and wondering what it would look like. i sort of got an idea now after seeing the one on that..
Post by El_Freddo » Wed May 11, 2011 9:45 pm
daza wrote:Who are you building your car for, you or the spectators?
Thanks Daza, you're good at lifting the spirits.
Nah, I was amazed that someone's managed to get engineering for this setup.
And the build is for me, but I don't mind the odd spectator ;)
ScubyRoo wrote:Bah, that hump of junk has nothing on Ruby. Those rims look awful and I'm not a fan of those weird rear tire carriers.
Thanks Owen, but I think you're biased, not that I'm complaining!
AndrewT wrote:You didn't know that somebody had slapped a lift kit and an EJ in an L series before? :)
Very funny!
AndrewT wrote:Gearbox setup is interesting. The interior looks like it's an L series box so must have been cracked open to have 4.111 diff put in, rear diff is probably a VLSD one from an early RS unless it's an RX CLSD that's been re-ratio'ed to 4.111. If it is an AWD one then that's obviously quite rare.
Yeah interesting about the diff, I just presumed it would have been one of the clsd units. The gearbox is what I'm working towards. I'm keen to know who did the engineering too. Think I need to send this fella a message.
skrewd wrote:i was only talking to my boss this afternoon about building one of those roof racks and wondering what it would look like. i sort of got an idea now after seeing the one on that..
I've been thinking of a rack up the top, but dunno what I want really plus I tie heaps of different stuff up there and a basket might get in the way...
Post by RSR 555 » Thu May 12, 2011 5:29 am
El_Freddo wrote:A couple of things I would love to know about this: What lift is used? Body/strut?
Looks like a 3" body and strut lift from these pics of the engine bay and RHR wheel shot.
El_Freddo wrote:The 14 inch rims - how they were made, if the stock centre was taken and welded to a 14 inch ring for the rim, why not use a sunraiser rim for better looks?
These are standard Subaru L series 14" rims that were available as an option in Japan (and maybe in USA??) but are EXTREMELY rare to find now days :( The wheel trims are also factory issued ones.
skrewd
Post by skrewd » Thu May 12, 2011 8:43 am
i was thinking of just a flat rack as in just the mesh floor, not actually a high sided one. that way if its no good i'll just build the sides up a bit higher :-D
Venom
Post by Venom » Thu May 12, 2011 12:23 pm
Bennie why don't you give Brian a call and ask him about it? If he can point you towards an engineer who has already certified everything you've done to your car it would be a good start.
Post by El_Freddo » Thu May 12, 2011 2:01 pm
RSR 555 wrote:Looks like a 3" body and strut lift from these pics of the engine bay and RHR wheel shot.
The thing that makes me wonder about the lift is that the factory bash plate is still in use without modification like I've done to mine, plus the alloy checker plate exhaust bash plates are the same in that they wouldn't clear the factory EJ Y pipes.
I didn't know this about those rims. I thought he may have had them made up... Sounds like a good find as they wouldn't be as heavy as the scorpions!
skrewd wrote:i was thinking of just a flat rack as in just the mesh floor, not actually a high sided one. that way if its no good i'll just build the sides up a bit higher :-D
That should work. My only thought is that the mesh could be noisy at speed unless you put a wind guard on the front of it to break up the air flow.
Venom wrote:Bennie why don't you give Brian a call and ask him about it? If he can point you towards an engineer who has already certified everything you've done to your car it would be a good start.
I've sent him a message via ebay. Might give him a call when I've got some time tomorrow.
