82 MY not sparking (first post)
Hi all
My old sportswagon came to a sudden halt the other night without any warning really. Engine cut out silently without any knocks or splutters. I've spent a bit of time with it, replaced the ignition coil and coil lead, but there's still no spark to the distributor and I'm not sure where to look next. It has a hitachi electric distributor which I've also overhauled as well. Any ideas much appreciated.
Check your fusable links next to the battery
Do you have a test light? I'd be checking power is at the coil when the ignition is on.
Yeah I've got power to the coil tested with a lamp and I've ordered a Tridon module which looks the goods for $105. Struggling to pull the distributor out now. I've make my markings and removed the two lock down bolts but it's not budging. Any tips? Is there anything else I need to do to get the thing out?
no need !! Pull the cap off, pull the rotor button off, pull the plug that should be found in the top of the shaft, use pick / scribe. No 2 Philips screwdriver should be right to undo the screw below. Need two smallish flat blade screwdrivers to lever the stator thingy off the shaft careful of small roll pin inside against shaft. Screwdriver undo securing scrws for modul and watch the brass spacers underneath that screws go through if they have them on EA81 dizzy.Oh yeah disconnect the wires carefully, give a squeeze to the female terminals to ensure a tight fit on install
- littlewhiteute
You can do the module in car, but if you want to pull the dizzy out, you need to rotate it first to free the o-ring in the block and/or the dizzy housing is stuck.thecamel wrote:Yeah I've got power to the coil tested with a lamp and I've ordered a Tridon module which looks the goods for $105. Struggling to pull the distributor out now. I've make my markings and removed the two lock down bolts but it's not budging. Any tips? Is there anything else I need to do to get the thing out?
You'll never pull a dizzy straight out without rotating a little first.
Gary
Gary
yeah... +1 for what Gazza said. I usually twist/rotate whilst pulling upwards but make sure you have the engine/rotor button set to TDC #1 before you try though
- Silverbullet
