Check out my new work bench!
ScubyRoo
Post by ScubyRoo » Sun Feb 20, 2011 10:55 am
$275 and a bunch of recycled materials, and quite a bit of time results in this...
Super stoked with it as I can now find all my tools and don't have to work on the floor / dodgey table :mrgreen:
Storage storage storage and organisation! I used new structural 2x4 to build the bench, 4x4 posts as legs and yellow tongue flooring for the bench. The peg board was painted yellow as the white coating soaked up greasy finger prints, and painting it a darker colour would have made the whole space to gloomy... and the cabinet was made from broken yellow tongue. All up I spent about $275 on new materials + odds and ends.
The shelving unit is made from an old patio table's top which had seen better days and my car's old wooden bed which we hadn't used in ages was used to frame it up - I even recycled the screws from both pieces of furniture! I used left over merbu decking oil to stain the timber and table top to protect against spills. A piece of rubber mat sits on the table for a non slip surface and is great when working on car parts as they can't slip and any oil is easily mopped up. I scored a Dawn 165mm vice off gum tree which I picked up yesterday and is going on today ($30, score!).
The whole unit is free standing, and can be disassembled 'Ikea-style' into flat pack to go with me when I eventually move elsewhere.
Dimensions are 2.75m long, 1.10m deep (80cm work space in front of cabinet/shelf) and 110cm (I think) high.
As there's no power or lights on this side of the garage I've run an extension cord along a rafter and tucked it behind the shelf. It has a 4-port power board which hangs inside the shelf and out of the way of any water/oils/wood chips. I've temporarily put an old lamp on the bench as general lighting until I can sort something better out. I've also rigged up my car work light to hang horizontally to give workspace lighting - this is connected to a spare 12v car battery which I can recharge when needed - and can also be moved anywhere around the garage! It also takes care of my kayaks, which I'd be struggling to find somewhere out of the way to store in the garage.
Super stoked with it and you'll see it in a few pictures that are coming up with a sneaky project I've been sitting on.
Owen.
Post by steptoe » Sun Feb 20, 2011 11:46 am
If it is anything like my bench it will be covered in al sorts of stuff in no time. When you need space just swipe it all into a box and start again. Looks good. Clever work height you have too. Can see you have a piece of scrap to protect top as well
olddog642
Post by olddog642 » Mon Feb 21, 2011 12:50 am
Looks good, yeah it's a real bugger when you don't have a bench or even someplace to put one.
I ended up having to build a shed so I could have all my stuff set up and a bench or two to work on.
Good one and I can see many happy days buggerising about in your newly establish work area.
Hylton:twisted:
Post by El_Freddo » Mon Feb 28, 2011 11:42 am
Good stuff Owen! I reckon it'd fit in well with the working space you've got at your joint... Can't wait to know more about this sneaky project of yours!
Post by RSR 555 » Mon Feb 28, 2011 2:46 pm
Yes.. that looks great and can see something awesome being built on it :mrgreen:
