DCCD RWD conversion
DCCD RWD conversion
G'day,
if I set me DCCD to full lock and remove my
front shafts, it cope in RWD for very long?
Only about 200hp
cheers,
Samuel
Only about 200hp
cheers,
Samuel
what are we expecting to cope?
and what are you planning to do?
we went drifting in one last year, not sure on the specs though was just a wrx and that held out fine with 250 or about that had the replaced front diff thingy though
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Nope
The DCCD uses a multiplate clutch to lock the speeds of the front and rear output shafts (of the planetary centre diff) The diff still handles the brunt of the torque, the clutches just help.
Removing the front driveshafts will only destroy a perfectly good DCCD differential.
- brumbyrunner
You should give your DCCD to me, i'll cover postage
Yeah they are worth chips, common as.
You will probably have problems giving it away
