How to: Replace MY shifter bushes (photos)
Post by Silverbullet » Tue Jan 18, 2011 6:49 pm
*EDIT 1/08/16*
Images have disappeared again, looks like image hosts must clean out their servers every 2 years. I'll try and upload them directly to the forum this time. Pics are still tiny, sorry
*EDIT 5/08/14*
Imagecrapshack decided to delete my pictures recently, I had to find a cached version of the images which were much smaller than the originals. I've re-uploaded the images I found but they are now very small, sorry!
*END EDIT*
I said I might do a picture tutorial on how to do this for those (like me) who weren't sure, so here it is!
I didn't get photos of the underside of the car, at least not yet. I didn't want to get my greasy mits all over the camera :rolleyes:
I also didn't get pics of the first step since well...I forgot :eek:
Firstly, take all the plastic parts off (only about 5 screws) to reveal the rubber boot and 4WD selector levers (rod A and rod B in the manual). You can undo a single nut at the base of the selector lever to loosen it, and undo the large nut holding rod A and B together (this one can be really tight)
Wriggle and slide the selector off of it's bolt and set it aside.
Now undo the 5 screws holding the rubber boot and it's plate in place, and slide the boot off of rod A and the gear shifter, set aside.
Now you should be up to here, where we have pics!
To get to the bushes, you will need to undo the 12mm nut and bolt (highlighted in green below)
Remove the bolt and carefully lift the whole gear stick away to reveal the bushes and spacer where the bolt went through (highlighted in red) and a single rubber bush at the very base of the stick.
These are the old bushes and spacer, which in my case turned out to look nearly like the new ones (explained later)
Remove the old bushes and spacer, and assemble the new rubber and resin bushes like the old ones.
Slide the bushes into the hole in the gearstick, and in my case I had a metal spacer that went through the the middle of the bushes.
Remove the old single bush at the base of the gear stick, and press in the new one with the groove facing up.
Assembly is the exact reverse of disassembly, just make sure the gear stick is seated all the way down so you can get the nut and bolt back through.
That's pretty much it for the bushes.
I can't make a tutorial on how to replace the roll pin further down the shifter mechanism, since the one on my car had already been replaced with a nut and bolt. This nut and bolt had come loose slightly and that was causing all the slop in my gear stick, so the bushes weren't worn out at all :-x
I removed, cleaned and replaced the nut and bolt from underneath the car and that was the hardest part of the whole thing. I made sure to tighten it as much as I could, which almost completely removed all the sloppyness in my gear stick...making this whole exercise almost completely pointless! :rolleyes:
Not completely though, the but and bolt still isn't quite doing the job properly, and I know for certain it will not stay tight for very long. When that happens I will get a new bolt and LOCKING nut, and cut a horizontal slot in the tube so it will properly clamp down on the shifter rod. When that happens, I will take some pics of what's going on underneath.
Hope this helps for all those like me who want to know how to reduce the slop in their gear stick. Any tips and suggestions welcome, I'll add them in.
Cheers!
download (3).jpg (6.25 KiB) Viewed 10963 times
download (2).jpg (7.98 KiB) Viewed 10962 times
download (1).jpg (8 KiB) Viewed 10964 times
sholinguteman
Post by sholinguteman » Wed Jan 19, 2011 6:35 am
So thats why my gearstick feels like a spoon stuck in a bowl of custard:-D.. Thanks for posting this , now all i have to do is find some bushes this side of the world LOL "MO"
Post by TOONGA » Wed Jan 19, 2011 9:22 am
sholinguteman wrote:So thats why my gearstick feels like a spoon stuck in a bowl of custard:-D.. Thanks for posting this , now all i have to do is find some bushes this side of the world LOL "MO"
yep it could be the bushes or it could be the shifter connector
http://www.indysworld.com/80s/general/U ... erFix.html
an interesting read with some nice modifications :)
littlewhiteute
Post by littlewhiteute » Wed Jan 19, 2011 9:34 am
Yes, have used that fix, but fit the bolt from the top.
If the nut comes off, the bolt will stay.
Gary ;)
Post by Silverbullet » Wed Jan 19, 2011 11:30 am
littlewhiteute wrote:Yes, have used that fix, but fit the bolt from the top.
Good tip, but if you do that make sure the nut and end of the bolt sticking out the bottom is no longer than it would be if it was the head of the bolt, my bolt was way too long and when I put it in from the top, you couldn't get it into 1st or 2nd gears because it fouled on something underneath.
thunder039
Post by thunder039 » Mon Sep 17, 2012 8:19 pm
found it ;) now to attempt :rolleyes:
2004 subaru forester -gone
1989 subaru brumby- sold!
2008 zook jimny -sold!
Post by El_Freddo » Mon Sep 17, 2012 8:38 pm
I've done the bush in the base of the stick and the bolt and slot trick. Worked a treat, but now I think the bush needs replacing again - it was 2nd hand in the first place.
The other way to fix this is an L series gearbox :p
thunder039
Post by thunder039 » Tue Sep 18, 2012 11:42 am
i would but i actually like the 4sp, i wont do the gearbox until i get my forester back otherwise i will be car less. so at the moment im just avoiding having to reverse lol
Post by Silverbullet » Tue Sep 18, 2012 5:15 pm
You found it! Well done thunder, I couldn't even find it from my user control panel :rolleyes: As for taking pictures of where the roll pin/nut and bolt goes from underneath when it came loose again, it never came loose! Still driving around to this day.
B00sting
Post by B00sting » Wed Sep 19, 2012 12:02 pm
Good thread and sure to be helpful for many (as this is so common on nearly all brumbies).
-97 Landcruiser :D
Ben248
Post by Ben248 » Sun Feb 17, 2013 9:01 pm
Can you please point me in the direction of finding new bushes, as i havent been able to find any for my 89 brumby?
cheers
Post by Silverbullet » Sun Feb 17, 2013 9:05 pm
FROG here on the forum sells the kit
member.php?u=906
Post by steptoe » Mon Feb 18, 2013 6:59 am
Or here >>>>>> index.php under the banner "classifieds"
frogs parts
taza
Post by taza » Sun Aug 03, 2014 10:19 pm
Pic links are broken... could they please be repaired?
Post by Silverbullet » Sun Aug 03, 2014 10:45 pm
I don't understand why they disappear, my signature pic is gone as well but they were all uploaded to my imageshack account which I still use...I'll have a look at my albums to see if they're still there but otherwise unlikely I still have these pics saved on my PC, that was my old PC.
taza
Post by taza » Mon Aug 04, 2014 8:59 am
Could you open them from yoir acoount. Save them to your current computer and re upload them.
Ive had a similar issue with my image shack account. I recently stopped using it with the latest updates.
Back to the brumby. My shift will touch both people knees in any gears. It isnt super sloppy but not great.
Post by Silverbullet » Mon Aug 04, 2014 10:40 pm
It seems those images have gone from my Img shack account as well, damn! :( This thread is useless without images, sorry to those who need to do this fix!
It's a fairly straight forward process anyway, I've found the largest contributor to shifter slop is the shifter forks tube being loose on the gearbox selector shaft. A big bolt and locking nut done up super tight is the best fix.
Post by Bantum » Tue Aug 05, 2014 2:51 pm
If you right click on the missing photo, go to the properties section & find the 'address' & then do a search for it in Google - it will have a cache memory of it. Should then be able to re-save it in your new photo bucket account ... :p
Cheers, Bantum ...
Post by Silverbullet » Tue Aug 05, 2014 10:37 pm
Bantum my man you have saved the day. The images did still exist somewhere in googles' archives, but they are much smaller resolution than the originals. I have re-upped the ones I've found.
Post by Bantum » Mon Aug 01, 2016 1:38 am
Hmm you might have to load them up some where else, as they seem to have disappeared again ... :(
Ciao, Bantum ...
