help with cooling system
69terra69
Post by 69terra69 » Thu Jan 13, 2011 10:18 pm
hi guys i have a 92 lib gx and it seems to over heat really quick.
if its stone cold and i start it and let it idle within 5mins the coolant starts overflowing from the reserve tank and its pretty hot has anyone know whats goin wrong?
i have flushed the system brought a new thermostate and radiator cap i just have no clue whats wrong i think the radiator cap is opening b4 the thermostate ? i dont know so has anyone had the same problem ?
cheers james
Post by RSR 555 » Fri Jan 14, 2011 6:16 am
Sounds like the symtoms of a head gasket but without seeing it first hand I'd hate to tell you so.
GTlegs
Post by GTlegs » Fri Jan 14, 2011 6:55 am
If it blows coolant out of the expansion tank then 90 percent its a headgasket issue.
If there is a crack in the head gasket between the water galleries and the cylinder, the pistons going up and down pressurise the cooling system and push the coolant out.
Post by guyph_01 » Fri Jan 14, 2011 7:21 am
Hi mate,
Sounds like your car has a head gasket problem. Well you have two options, maybe three but the third is real expensive.
1, Buy a second hand engine, 300-600 depending on how good the engine is.
2, sell the car as is
or 3 rebuild the engine.
But get the car tested first if you can, buy RAC if you got it to make sure its the heads. but definately sounds like it.
rebuilder
Post by rebuilder » Sat Jan 15, 2011 2:36 am
well 69terra69 im ur man, i rebuild these subaru motors a lot.
Can i check it out for u? send me a PM and ill organise to have a look,
Firstly, did this just suddenly start happening, or did you buy the vehicle like this,
Secondly, is there any white smoke coming out of the exhaust after the car has warmed up for 2 minutes, but no more than 5 minutes?? (time between burn off of exhaust moisture and operating temperature)
69terra69
Post by 69terra69 » Sat Jan 15, 2011 11:26 pm
hey guys thanks for the replys and sorry for the late reply
pretty much everyone i have talked to has told me head gasket so im sure it is so not willing to fix that engine at all because never liked the power so im thinking of 2 options.
1.buy a 2002 wrx engine with loom and ecu but whats steering me away is its front wheel drive.
2.sell the car completly and start again.
whats your thoughts guys ?
Post by El_Freddo » Sat Jan 15, 2011 11:54 pm
69terra69 wrote:hey guys thanks for the replys and sorry for the late reply
Convert your lib to AWD, its just a different set of hubs plus the rear diff and support bits that need to be bolted in, find an AWD gearbox, tailshaft and gearshift linkages and you should be sorted, the fuel tank may need to be swapped too, I'm not sure.
If you think it easier you can start all over again with an AWD lib from the beginning... It will save you some time on a rear end conversion. Drop a second hand engine into your current ride and build up the new one ;)
69terra69
Post by 69terra69 » Sun Jan 16, 2011 12:14 am
yeah what i was thinking mate cause i can get the rex engine for 800 so im thinking thats pretty cheap. whats rough price for awd conversion ?
thanks james
Post by RSR 555 » Sun Jan 16, 2011 12:30 am
Sell it at buy Tristan's (90Brumby) already converted Liberty and you'll be happy. At 5k you wouldn't waste your time and efforts converting one :)
69terra69
Post by 69terra69 » Sun Jan 16, 2011 12:56 am
hi yeah would love 2 man just dont have the funds at the moment will prob sell and slowly get the parts needed and do it all in 1 shot.
cheers james
69terra69
Post by 69terra69 » Sun Jan 16, 2011 1:46 am
hey guys another quick question if i was to get the 02 wrx engine how much trouble is it goin to be to get the wrx loom to work in the lib ?
and will the lib auto box bolt straight up the the wrx motor ?
thanks james
Post by El_Freddo » Sun Jan 16, 2011 5:33 pm
69terra69 wrote:yeah what i was thinking mate cause i can get the rex engine for 800 so im thinking thats pretty cheap. whats rough price for awd conversion ?
Depends on the variables - cost of parts, labour if you're paying someone to do it or if you're doing it yourself...
Best way to go would be get a liberty with a dud gearbox or something that's wrong with it that you don't need for yours - like a rear ended one - get it cheap. Pull the rear end out and put it into yours with the matching gearbox. If the engine is good might as well drop that in rather than fix your current hot block in there.
From here look into the turbo conversion which leads onto:
69terra69 wrote:hey guys another quick question if i was to get the 02 wrx engine how much trouble is it goin to be to get the wrx loom to work in the lib ?
Anything is possible. If no one can help you out here contact al at amauto.com about it as he'll know and would be able to cut down the two looms (you send them to him) and make one that works.
As for the auto - waste of time - where's the fun???
rebuilder
Post by rebuilder » Sun Jan 16, 2011 7:26 pm
i live in perth and would love to do ur rebuild for u for cases of beer.
I win at subaru rebuilds, and i jsut think theres no point spending money on new engines when its not actually that rediculous to rebuild.
costs are as folows
$700 bucks for gasket set (complete set with every gasket)
OR ~$400 for 2 head gaskets
plus coupla hunjy or so spare in case for posiibility of machining block and heads mating surface!
$200 for: oil, coolant, beers, and filters
69terra69
Post by 69terra69 » Sun Jan 16, 2011 7:38 pm
sweet guys thanks for replys think i mite get u dud awd lib put it all onto mine and get this wrx engine and then get someone to do the looms for me.
so a little bit more into it will the ej20t drop straight into the lib no probs or is there fabrication involved ?
cheers james
