WTB l series fuel in line
Mr Top Hat
Post by Mr Top Hat » Thu Jan 13, 2011 5:04 pm
hey Guys
does anyone have a carby L fuel in line or mpfi return line in their shed somewhere?
A-part wreckers says they dont really do L series stuff anymore.
and it holding up my conversion because i need a bigger return line for the EJ22
and would the standard carby fuel in line be ok for the EJ22 fuel in line right?
thanks
Rob
1990 L series wagon Ej22
i didn't realize this image was so large :-O
Post by Alex » Thu Jan 13, 2011 5:39 pm
from memory i just beafed up the fuel lines to EFI lines and used all proper worm drive hose clamps. The standard clamps and hoses arent beafy enough.
Post by El_Freddo » Thu Jan 13, 2011 8:33 pm
Mr Top Hat wrote: and would the standard carby fuel in line be ok for the EJ22 fuel in line right?
Yeah Rob I'm running a standard carbie fuel-in line for both the in and out lines. No issues from a fuel pressure point of view.
The extra fuel in line can be a pain in the arse to get in, I didn't cut mine down as I wanted to retain the crushed out buldge to help seal the line, so its got a massive "S" shape under the bonnet. I simply cable tied with some foam to the other fuel lines to mount it. Then did the rest as Alex said - beefed up the rubber lines and clamps to EFI rated stuff ;)
Mr Top Hat
Post by Mr Top Hat » Thu Jan 13, 2011 8:40 pm
oh really so all the excess fuel can happily go through the carby fuel return line, no surging?
GOD
Post by GOD » Thu Jan 13, 2011 8:44 pm
Mr Top Hat wrote:oh really so all the excess fuel can happily go through the carby fuel return line, no surging?
A surge tank is a good idea (getting halfway up a steep hill and having the engine starve and stall can be scary), but your metal carby fuel lines will be fine. Replace existing rubber lines with EFI-rated hose.
Dane.
Post by El_Freddo » Thu Jan 13, 2011 8:46 pm
Sorry, you've miss read my last post. I'm using a fuel IN line for the return line as well - sourced from a carbie fed L series, just reshaped the end in the engine bay.
With a standard carbie return fuel line my MPFI I had a few years ago would surge under acceleration but didn't do it all the time. Had me stumped as it did it with two different engines... So I swapped the return line when the EJ went in - no issues with fuel so far, just cam belts and bearings after drowning the interior...
Worth the effort I reckon for piece of mind if you can source the stock carbie fuel IN line ;)
Post by guyph_01 » Thu Jan 13, 2011 8:47 pm
I think i kept a few bigger fuel lines when i moved. I can check when i get back and let you know if you want bigger lines.
Mr Top Hat
Post by Mr Top Hat » Thu Jan 13, 2011 8:55 pm
guyph_01 wrote:I think i kept a few bigger fuel lines when i moved. I can check when i get back and let you know if you want bigger lines.
yes please. when do you get back?
Post by El_Freddo » Thu Jan 13, 2011 9:09 pm
GOD wrote:A surge tank is a good idea (getting halfway up a steep hill and having the engine starve and stall can be scary), but your metal carby fuel lines will be fine. Replace existing rubber lines with EFI-rated hose.
Have you not "upsized" your fuel return line Dane? Had any issues with over pressurising of the fuel due to the return line being a restriction?
El_Freddo wrote:I also changed the fuel return line for another L series fuel to engine line &#8211]http://img514.imageshack.us/img514/2163/p8081609.jpg[/IMG]
Quoted from here
There's a comparison to the stock carbie return line and fuel in line, hence why I swapped to a fuel in line for the return ;)
Painful job though, interior has to come out down the left hand side of the subi, you should have enough room under the dash to get it in, I just managed to do mine with the dash in!
Post by Alex » Fri Jan 14, 2011 9:43 am
i never touched my return line.
i did have overpressurising problems, but only on hot days, she did surge abit.
if you disassemble your fuel cap, drill a hole in the little metal bit and replace it youll be fine :)
worked for me.
Return to “Western Australia”
