WANt L series clutch cable
tried to post this in the wanted section but it wouldnt let me for some reason.. need a clutch cable for an l series or any clutch cable that is longer than an l series... 0400 896 273, cheers oliver
- TOONGA
Ollie you are a non subscribed member,
showthread.php?p=109295#post109295
If you subscribe then you will be able to post in the classified section.
How come you need it longer?
L series cables are available and affordable from Subaru. Give the Melville branch a call.
- d_generate
I'm after a 92ish Liberty one if anyone has one laying around, just to carry as a spare.
Hey Ollie.. how did you go? I hope you got it fixed?
When I replaced my L's clutch cable (best thing I've done along with the EJ, 3inch lift and 27's) my local parts joint couldn't get an aftermarket unit so had to order one from subaru. I think it cost about $70. A little steep but a HUGE improvement over my last clutch cable with turned out to be trying to chew through its side wall everytime you used the clutch pedal! It was probably like this when I originally purchased Ruby Scoo...
