Lsd baby
Lsd baby
hey again,i'm planning to remove lsd diffs from a car at the wreckers,can anyone tell me which car/wagon to look for to get 4.44 or 4.11 lsd front and rear.where do i check to know?also can i get some sort of lockable or lsd centre diff to fit ej22 5sp dual range????for any help,i'm new at awd drive thing and want to smash my mate's courier down the beach hehe
[SIGPIC]
[/SIGPIC]
G'day and welcome,
your chances for getting a front LSD of any subaru description in a wreckers is bucklies and none.
With subaru's, you cannot simply remove the front diff as it is located INSIDE the gearbox.
looking for a gearbox with those specs, its going to be imported.
Currently Jason from ALL THINGS SUBARU in Lawnton Brisbane ( http://www.funonwheels.net/ )
has a JDM STi 4.44 Front LSD box for sale and has matching plated rears in stock.
As for the LSD or lockable centre. you do have options.
Factory LSD Centre
Aftermarket LSD Centre
Factory Diff lock ?
Factory DCCD (Driver Centre Diff Control) - is nice....i have one in mine
either way, its going to have to be some kind of frankenstein hybrid for the DR setup
JEFF from Crossbred has an animal brumby with the exact combo gearbox that you are looking for and may have a spare. Hit him up on info at least.
here are some spots for good reference for your search
http://members.iinet.net.au/~wearne/Sub ... 0Specs.pdf
http://www.ausubaru.com/wiki/index.php? ... ANSMISSION
hope this helps
Samuel
Factory LSD Centre
Factory Diff lock ?
hope this helps
Samuel
are you from williamstown sa or elsewhere?
Yeah its best to get wifeys approval first or else the handbags will start rolling in
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
With the right driving skills your little subi will kick your mates courier on the beach. The L series low range (1.59:1) in the EJ AWD gearbox will be a huge improvement over the standard EJ low range (1.19:1).
Some lift will be an advantage too. If the avatar is a liberty and the subaru in question, you should be able to do a strut lift at the very least. A body lift with a larger strut lift would give the best possible lift when combined with larger tyres...
Mm pretty hard to find but if you go to the right direction they're there.
See my thread about conversion of 1.19:1 to 1.59:1 low range ratio, mine is still going strong.
Only way to find out is to inspect the rotation of the wheels in wreckers and shut your mouth at the counter guys if its LSD because they'll push the price up.
what wreckers are you heading to?
if not try paul at subarwreck, tell him i sent you and you might get a discount but dont tell him how much your going to pay cause he will just ignore you
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Tried that.. either he doesn't like you or he is in dreamland.. $800 for a diffspike wrote:what wreckers are you heading to?
yeah i would pay $800 for a rebuilt EA LSD with a warrenty which hey might be a lot especcially for what cars they are but that still seems reasonable to me
GETDIRTYCLOTHING
GETDIRTYCLOTHING
No mention of rebuild and I very much doubt he would sell it with a warranty on offroad equipment.. most wreckers dont
and I'll let you pay $800 for just a diff.. we can buy the whole car for that price and you'll get free rear discs
paul is forced to give a warrenty as he is a member of the hotline 40 auto wrecker mobs
and whenever he gets them they get rebuilt and usually sold to the rally guys
if i could get a standard subaru L here for 800 well yeah but you cant unless you look really hard most go for about 1500
GETDIRTYCLOTHING
GETDIRTYCLOTHING
