Cheap and Ch:):)rful mod for MY
Post by steptoe » Wed Dec 29, 2010 10:53 pm
Get that extra go out of your old MY series Subaru.
It is cheap
It is easy to do
and the extra GO you can get out of it for just a few minutes work with zero outlay, is well worth a try.
If you don't have removable floor mat in your drvers floor well, you will need one for this little miracle to happen.
It worked for me so I reckon it may work for others too and wished I'd done it years ago.
You know that top right corner of floor mat that gets stuck under the loud pedal reducing WOT - you cut it off :) getting maximum throttle cable pull
Post by TOONGA » Thu Dec 30, 2010 12:24 am
the other thing that can be done is bend the arm so you have more sweep in the pedal a simple grab of the pedal and a good strong pull will bend it upwards or pull the pedal off the box :)
Post by RSR 555 » Thu Dec 30, 2010 9:08 am
just make sure you don't bend it too much or you'll end up buying lots of accelerator cables :???:
Post by TOONGA » Thu Dec 30, 2010 9:35 am
I won't as Ive got a XF accelerator cable fitted to my weber :)
but yes others will :)
