Is this really EA82T ECU?
Bodge
Post by Bodge » Thu Dec 16, 2010 8:54 pm
G'day,
I have just picked up an EA82T and it came with an ECU just wondering if it really the right one.
It has three codes on it,
- 22611 AAOO2
- AII-000 972
- 5902
I did try the search function but couldn't find anything.
Seems to be a 3 plug ECU, wiring loom on the engine seems to have 2 plugs tho at a quick glance?
I should be able to trust the bloke on his word, but he thought it had been "rebuilt" by his mate but I really doubt it by appearances! Could be anything...
Hope someone has the codes.
Cheers.
H-top
Post by H-top » Thu Dec 16, 2010 9:15 pm
rip out the plugs and use torch or scope, can tell u alot about history and how its run.
there should be at least 3 plugs.
what did it come out of?
H-Top
rolling in
Bodge
Post by Bodge » Thu Dec 16, 2010 9:37 pm
I have no idea what it came out of, old mate had it lying in his garage in front of his car. He thought he could use it as an upgrade motor for his EJ16 Impreza!!! (1.8 is bigger than 1.6 :rolleyes:)
So I don't think he really knew a lot about it!
And what his "mate" told him about it was largely rubbish, Doubt it has ever had a rebuild.
He also thought it was from a '95 model vehicle but I think '85 would be closer to the truth. (not that I know a hell of a lot about subies)
I didn't get a loom with it, just the ECU and the wiring on the actual engine.
Glad you mentioned pulling the spark plugs, I'll get onto that for sure.
Hopefully one day it'll go into a Brumby or an L series.
edit - ECU does have 3 plugs/ports. Also says 'japan electronic control systems co. ltd' below the ID codes.
H-top
Post by H-top » Thu Dec 16, 2010 10:48 pm
No worries mate, that is what JECS stands for.
If u only have engine loom and ecu, u have Alot
of wiring ahead!
Put some pictures up!!
H-Top
rolling in
Bodge
Post by Bodge » Fri Dec 17, 2010 8:54 pm
Thanks for your help.
This gear will most likely sit in the shed for a while before I make use of it so there won't be any project in progress pics just yet!
My L series already has an EA82T, might sell it on sometime next year to kickstart me into project mode. To make room for one too!
I haven't had a real hard look yet but the intake plenum(?) seems larger on this engine than the one I already have fitted. Is this an indication of the original donor vehicle?
Thanks again.
Sorry to hear about your Vortex. Looked like a really sweet ride.
Tim.
H-top
Post by H-top » Fri Dec 17, 2010 9:01 pm
No worries
yeah mate, bummer. I'll resurect one someday
H-Top
rolling in
SCOOBIDOO
Post by SCOOBIDOO » Thu Dec 23, 2010 9:21 pm
Bodge wrote:G'day,
- 22611 AAOO2
- AII-000 972
- 5902
Cheers.
i have 3 known turbo ecu,s here
your numbers quoted will suit a 3 plug turbo ea82 application.
THE FASTER THE SPEED - THE BETTER THE IMPACT...SUBARU
SCOOBIDOO
Post by SCOOBIDOO » Thu Dec 23, 2010 9:23 pm
Bodge wrote:G'day,
- 22611 AAOO2
- AII-000 972
- 5902
Cheers.
your numbers quoted will suit a 3 plug turbo ea82 application, in auto or manual depending on which discrimination you trigger.
Bodge
Post by Bodge » Sun Jan 02, 2011 2:20 pm
Excellent!
Thanks Scoobidoo, that's great to know.
Cheers.
