will it fit?
poprock1
will it fit?
Post by poprock1 » Wed Dec 08, 2010 4:57 pm
Hi; I have seen a clutch plate on ebay for a brumby $30, mine is an 89 L wagon; Will the brumby plate fit?:confused:
Post by AlpineRaven » Thu Dec 09, 2010 7:58 pm
Quick answer no.
Post by El_Freddo » Thu Dec 09, 2010 8:15 pm
poprock1 wrote:Hi; I have seen a clutch plate on ebay for a brumby $30, mine is an 89 L wagon; Will the brumby plate fit?:confused:
Just get a new one - this way you won't be pulling your L apart any sooner than you have to due to the clutch giving out again.
Plus a new clutch disc WILL be at maximum thickness, unlike something you could be buying on ebay...
Post by TOONGA » Thu Dec 09, 2010 8:40 pm
if it is new it is really cheap, but having said that it definitely won't fit properly in to an L series, as the brumby clutch plate itself is thinner than the L series clutch plate, which would cause it to slip all the time as the pressure wouldn't grab it properly
78sti
Post by 78sti » Thu Dec 09, 2010 10:50 pm
Won't fit onto the gearbox input shaft - totally different.
Post by TOONGA » Fri Dec 10, 2010 2:46 pm
78sti wrote:Won't fit onto the gearbox input shaft - totally different.
2 different size clutches 200mm and 225mm, 2 different spline sizes per clutch size 21 spline and 24 spline, but still won't work properly as Ive had this problem so has Guy when he put an L series flywheel into a brumby I think it was
poprock1
L clutch.
Post by poprock1 » Fri Dec 10, 2010 3:29 pm
Thanks guys; You are all correct. Rather than pay $130 for a new one I went to Budgewoi Spares (kurri branch) where they said they had one but still in car but if I was prepared to take the risk I could pull the motor out and see what it was like. They were quite surprised when I said ok; and 90minutes later I had a good clutch plate; 2 rear gas t/gate struts and various small items for $20 and they had an E82 on the ground ready for sale. Still chasing passenger side front park/blinker lens.;small or big amber section . It has one of each at the moment.:cool:
ORX-18
clutching at clutches.
Post by ORX-18 » Fri Dec 10, 2010 6:22 pm
if you are looking for an alternative, ring Jim Berry at Race Clutch. he will sort you out with a pro clutch that will do EXACTLY what you want, and he is THE ducks nuts when it comes to clutches. He made me a 4700lb clamp on a holden gemini diesel disc, it had as much clamp as a button clutch and was as easy to drive as a standard one.
