primary main: 140
seconday main: 135
primary air: 160
secondary air: 165
primary idle: 50
secondary idle: 55
It has improved bottom end, excellent midrange and way more top than hitachi, but....when I engage secondaries it feels like the tuning is a bit rich. The note changes to a deep growl but unless I'm high in revs ie above 3500, it seems to choke a bit.
Also with the secondaries fuel seems to drop pretty quick. Now I know this is the nature of the weber and I get great mileage on the primaries. but... my ideal would be to use all of the primaries power (110 in 4th slight incline) and then creep a bit of secondary just to add a bit for the steep hills but not too much.
Basically I think the secondary is overkill at moment but primary is worth more than flat foot old hicrappy
Has anyone worked out the perfect second main jet and air correctors for L series?.
FYI Car has fresh engine with redline filter and 2inch exhaust cat back into turbo muffler and 13's for roaf. Fuel mileage is 8-10L per 100k's
Thanks to anyone who read this far it would be great to get the this weber running as close to efi as possible.
