Gearbox Options
Gearbox Options
Hi all,
just wondering what my options are for replaceing the original dual range box in the Brumby. I need to expand the life span of the Brumby without spending too much time or money.
Dan
Dan
The Achievement of convincing mum to get a Liberty, Being allowed to drive it PRICELESS
what are you trying to extend the life span of??
if its the engine, than a 5 speed
if its anything else find and pay the money for a awd DR
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
dont think they came in the brumby
check in the conversions and the gbox section
GETDIRTYCLOTHING
GETDIRTYCLOTHING
The Brumbys and M.Y. wagons were only available with the 4 speed gearbox (single or dual range) if you want anything else it will need to be a conversion. The L.Series 5 Speed dual range is a faily common conversion and you'll get plenty of help from this website
There are plenty of other options but if you're working to a small budget then stick with the L.Series box. When the budget becomes bigger and you would like to extend the Brumbys life (engine life) have a look at fitting the EJ22 from a Liberty.. another common conversion.
Paul
Paul
1+ You also could use Liberty/Forester/Impreza's AWD D/R box behind EA81.RSR 555 wrote:The Brumbys and M.Y. wagons were only available with the 4 speed gearbox (single or dual range) if you want anything else it will need to be a conversion. The L.Series 5 Speed dual range is a faily common conversion and you'll get plenty of help from this websiteThere are plenty of other options but if you're working to a small budget then stick with the L.Series box. When the budget becomes bigger and you would like to extend the Brumbys life (engine life) have a look at fitting the EJ22 from a Liberty.. another common conversion.
Paul
