brumby ej22 4 speed clutch and starter motor ??
- brockharro
i am planning on doing a ej22 conversion the old EA81 is getting a bit old with 360 thou on the clock just abit unsure with the clutch and starter motor i am planning on keeping the on keeping the 4 speed box
im assuming that you use the EA starter motor coz keeping the EA flywheel
and how hard is it to shorten the loom
Yeah use the 4spd starter, it works fine. I had this setup in WackyBug.
Re loom, if you haven't done one before it's extremely difficult and has lots of danger of ruining the loom beyond repair. Do plenty of research and preferably employ the help of somebody who has done several successfully before before you attempt it.
- brockharro
If you're using the EA flywheel then your going to need the EA clutch
- brockharro
It's always best to either buy a HD kit or if you have clutch rebuilders that can biff them up, then go for it
- brockharro
- brockharro
20% is heaps.. any more and you're going to need to mod your clutch fork
Don't expect the 4spd to last long if you're going to flog it often!brockharro wrote:thanks heaps
it really clears that up and i was planning to put hd in and i do have a tendacy
to flog stuff
As for the wiring, you can cut it down without the engine installed. This is how I did my conversion. If you can read a wiring diagram and enjoy tracing wiring through a pile of mess I'd say give it a go - Thats how you learn, and how I did it my first (and so far only) time!
All the best with the conversion, you'll love the 22
