Tech Manual
Mick G
Tech Manual
Post by Mick G » Thu Sep 30, 2010 8:04 pm
Why cant i read the Tech manual Looking for info on converting a 4 plug turbo back to Carby ea82
phillatdarwin
Post by phillatdarwin » Fri Oct 01, 2010 12:09 am
how are u going to bring the compressing back up so u can run a Carby as from what i have read a turbo engine is at 7.7/1 wear a Carby engine in 9.1 /1
Post by steptoe » Fri Oct 01, 2010 2:29 pm
be whole motor swap I imagine. Techno reverse. Power to coil, power to carby switches, hook dizzy up to coil and Bobs yer uncle I'd say. Unplug some of the ECU plugs. You need a normal pressure fuel pump too so disconnect efi pump circuit.Surely just follow a basic Gregories wiring diagram - someone may be able to help with a link
Mick G
Post by Mick G » Fri Oct 01, 2010 7:51 pm
steptoe is right Ive a donar Wagon. and the plan is to swap over the fuel pump, leave the high pressure fuel line in. I would like to keep the Computer and wiringfrom original turbo, but dont know if that is possible the other wagon dose not have electric windows cruse & so on. So i dont want to swap the whole loome?????????
Post by TOONGA » Fri Oct 01, 2010 8:33 pm
I did a quick test earlier on today and it seems the tech manual is now home to advertising for drugs to help with erectile dysfunction, staying slim/awake or anything to do with drugs in general.
is there a bot that has invaded the tech manual as I copied this page http://www.subarubrat.com/Retrofitting% ... V%2032.htm
and pasted it where the spam is now
a sample of said spam
http://huttonbrew.org#83921 buy xanax online legally - buy xanax overnight delivery http://downyonderbbq.com#86824 buy phentermine - phentermine http://cicpc.org#50566 cialis - buy cialis canada http://donteatthatyet.com#49987 buy valium - valium
any ideas Admins and mods
Mick G
Post by Mick G » Fri Oct 01, 2010 8:42 pm
Thnaks looks like were gettin there
Post by steptoe » Sat Oct 02, 2010 12:34 am
If I were to do this project I would be wiring up the EA82 carb as if it was an added accessory. Oil warning light and engine temp should hok up from loom to carb engine in same way, just leave all computer in place. more deas may come.....i
stephendean
Post by stephendean » Sat Oct 30, 2010 9:45 am
It seems that no-one from admins is looking after the Tech Manual. I have restored a few pages, which is a long process at times. Surely an admin could password the site.
There are still admins around I assume?
