replacing ej20 rear main seal
Do I need to remove the crank? Or can it be done with the engine still together, cheers
The old seal works well for this. It's the same sizeTOONGA wrote: and use something the same size as the seal as a guide to tap it back into place
Another good tip is also clean the 2 surfaces that the seal touches
And when installing the new one.. put some rubber grease (or vasoline) on the inside section where the crank runs and put a small bit of three-bond silicone on the outer section where it touches the block.
I also recommend you only use genuine seals but it's up to you
Thanks for the tips, will keep that in mind.
As for using genuine seals, I just found a whole gasket set on ebay rather cheap (I think), so that will have to do for now I guess.
http://cgi.ebay.com.au/FORESTER-IMPREZA ... arParts_SM
