Need some info RE 96' wrx
preno
Post by preno » Wed Aug 04, 2010 5:07 pm
ok so im looking for a boot lid, rear bumper and lhs tail light to suit a 96 wrx
what im wanting to know is what years/models share these same parts?
from my quick bit of research i think its from 94' to 00' that are the same. correct?
also is the standard impreza from those years the same body shape but just missing the rear spoiler? im thinking a wreckers will sell a standard impreza boot a bit cheaper than a wrx boot. mayb.
if you have any of these parts sitting around and want to get rid of them let me know :)
cheers
matt
Post by RSR 555 » Thu Aug 05, 2010 5:12 am
Hey Matt.. you're sorta on the right track with regards to the years of the classic shape Impreza.. Boot lid and Tail Lights are all the same, except STi and import tail lights are different to Aussie ones but if you use both you'll be ok. However there was a change of styling to the rear Bumper. As of MY97 onwards they looked slightly different and remember that only the WRX and STi had those spoiler pieces stuck to the bottom. You can fit your spoilter pieces to a standard bar if yours are still ok? Hope this helps :)
Paul
preno
Post by preno » Fri Aug 06, 2010 2:48 pm
thanks for the reply
ok so ive found out its actually a 97 model! was told it was a 96. my rear bumper is damaged but easily reapairable, its only the metal bracket inside that bolts the bumper to the car that is buggered. totally twisted. are these all the same through 94 to 00 with any impreza?
cheers
Post by RSR 555 » Mon Aug 09, 2010 3:43 pm
The metal frame is called the bumper reinforcement and yes they are all the same from 1993 to 2000 (Classic Shape - GC body code)
Sorry for not replying earlier :(
preno
Post by preno » Mon Aug 09, 2010 4:23 pm
thanks mate! :D
Jeff
Post by Jeff » Mon Aug 09, 2010 5:36 pm
Not sure how to reply in the wanted section but i have both Bootlid and bumper in QLD if you get stuck
preno
Post by preno » Mon Aug 09, 2010 5:53 pm
thanks jeff, currently got my eyes on some parts bit closer to home. but the shipping is still nearly as much as the parts!!
anyway ill give u a yell if i need either
cheers
matt
