Hope title explains for easy searching. Just thought I 'd post up part numbers of the clutch disc I used when install L Series 5 speed DR 4WD with a 200mm clutch on my Brumby a few years back. NOTE it is the smaller diameter clutch
I bought just a disc to use std Brumby pressure plate
The disc number for Holden Gemini by Isuzu 1.6l petrol RWD is R7926W
Nissan number on box is NSD026
OD 200
ID 130
ST 24
MD 25.6
L Series 5 speed > Brumby clutch details
On the topic of Part numbers, i've just sourced new inner doj's for my DR 5 speed L box (from turbo touring wagon) into brumby, did the mix and match using brumby knuckle inside of ej20 89-93 legacy/liberty cup,
Fargo part number 181530.
It seems that the cup is the same as the L series non turbo MPFI
